- Mute
- Permalink
- Report
HI All,
I'm new to Fusion and CAM in general and I've been trying to find how to setup my rig.
Let me describe my setup:
I have a three axis CNC mill with a 4th axis aligned with the Y axis.
Mounted on the fourth axis, I have a box on which I need to machine four faces. Box rotates and Z goes down and holes are cut.
I got all that figured out but I have difficulty in getting a reliable location for zeroing my G54. I initially designed the CAM setup to have a WCS zero on a corner of the box but when checking the G code I realized that the heights were calculated that point and not from the individual faces that are defined in the tool orientation. That was a little unexpected since these menus show distances according to these face coordinate systems... but anyways...
I kind of have a working setup now where if I put the setup origin on the rotation axis I have all the limits heights OK but now, I would have to zero from the middle of the piece which is quite difficult, as least given my current knowledge of things.
So my question is, what is the best way to go about that? Should I keep the setup zero on the rotation axis and find an external way to find my G54 zero. Or should I try to find a way to get the limits and heights right with Fusion with an off center setup origin. Or, should I try to find another zero point which would be on the piece that is holding the box (which is a cylinder).
Thanks for your help!
