3D object skew transform
omidmostachfi
Observer Observer
omidmostachfi
Observer
Observer
I have a complex 3D object that I've created. I'm wondering if there is a way in fusion 360 to do a transform on the object so everything is angled at 45 Deg along one axis.  Mathematically, we'd have x'=x; y'=y+z; z'=z, see drawing below.
Note: I realize I can skew a 2D sketch at an angle by sweeping at 45 deg. What I'm looking for is how to transform an existing 3D object (the object is complex, not a simple cube, so redrawing it would be too difficult).
jhackney1972
I am guessing the technique for doing this with a Cube will not be applicable to a more complex model since I am changing the angle of the cube internal sketch.  Skewing a model directly I think will be hard in Fusion 360 since it does not have a "Stretch" command.  Model is attached
(view in My Videos)
John Hackney, Retired
omidmostachfi
Observer
Observer
Thank you very much for the video. Unfortunately, my part includes numerous sketches at various angles, fillets, holes, threaded parts, so I need to apply a global transform. If that’s not an option in fusion 360, I wonder whether there are any other programs that could do this on an exported 3MF file?
TrippyLighting
The shear tool in Blender will do exactly that.
3MF is a format hosting triangulated meshes and is not a format that works well as design input to Fusiosn360.
To work with this format in Blender you'll first have to find a plugin that reads 3mf into Blender and install it.
omidmostachfi
Observer
Observer
That’s awesome. Thank you. My project is a native fusion 360 file so I can export it in whatever format Blender needs (I just said 3mf as an example).
Thank you for your help.
TrippyLighting
@omidmostachfi wrote:
... My project is a native fusion 360 file so...
Just be aware that to export it into Blender, you'll have to export it into  a triangulated mesh format use. obj.
However, be advised that if you want to re-import the object into Fusion 360 and do further modeling work might be very difficult!
david.milan213
Community Visitor
Community Visitor
I may be late to the party, but I'll leave this here since this was the first result I came across when searching for solutions.
According to linear algebra a skew transformation can be composed as the product of rotation and non-uniform scaling, which are available operations in Fusion 360. I have successfully aplied this for a decorative element where I could 'eyeball' these operations.
For a mathematically rigorous procedure I found this:
https://stackoverflow.com/questions/18362043/shear-matrix-as-a-combination-of-basic-transformation
