- Mute
- Permalink
- Report
I use the 3D Contour toolpath very regularly, but am having a strange issue with this part. In this part there is essentially a slot with angled walls that runs the length of the part. On one end, the walls open outward at an angle. For some reason, I cannot get the toolpath to extend to completely cut where this happens. I first thought it was an issue with my containment parameter, but I have tried every combination of contact point boundary, containment boundary, machine shallow areas, separate toolpaths, etc for these surfaces. Touch surfaces is turned on, and all the surfaces I want machined are selected. A sperate toolpath with only the trouble surfaces selected will not generate at all.
The only toolpath I can even get to even generate is with Silhouette boundary, tool center on boundary(no offset), and contact point boundary off. I've attached a couple pictures so you can see what's going on. Tool is a 1/2" indexable ball endmill.
