3 point plane origin bug?
HughesTooling
Consultant Consultant
HughesTooling
If you create a plane using 3 points in a sketch the first point you pick will be the origin, this can be quite useful. If you edit the sketch the origin doesn't update but if you move a point in the Z axis it does! seems like it should update at all times.
This feature would be even more useful if the X axis aligned to the first 2 points selected, something for the ideastation I guess.
Mark
Mark Hughes
Owner, Hughes Tooling
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @HughesTooling
Thank you for reporting this issue!
I was able to reproduce it so It's logged under FUS-37695. If I receive any updates, I will get back to you. Thank you for your understanding!
I wish you all the best for the new year! Heart
Many thanks,
Ahreum.
HughesTooling
@Phil.E Would you mind taking a look at this screencast while we're discussing sketch origin problems. Notice when I edit the points the plane's created from the XY axis flip so X changes from pointing down to point up! Are there any plans for rotating and flipping planes because these sort of problems makes redefine sketch plane pretty useless at the moment.
Thanks Mark
Mark Hughes
