- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey all,
Newbie here...relative new...having been using Fusion 360 for about 2 months, in combination with a Ooznet Workbee and Makita router.
This weekend I was trying to make simple joints for a box, and noticed that simulation does not match the actual cnc milled result. (see drawing below, backup file also attached)
The distance between A & B in model is 18mm, but CNC mills it as approx 16m. The distance between C&D is also meant to be 18mm, but CNC mills it at 20mm. I am using a 1/8 inch (3.175mm) 2 flute up cut bit, which I have calibrated in the tool library. It looks like an offset of approx 1 mm for the router axis.
I am at a loss why this happens. Am I overlooking a setting somewhere?
