Request for post processor – HWACHEON HI-TECH 230 BL YSMC with sub-spindle
I would like to request a custom post processor (or an update to an existing one) for our lathe HWACHEON HI-TECH 230 BL YSMC used with Fusion 360 (Manufacture workspace).
On the Autodesk post library I can only find a post for HWACHEON HI-TECH 230 AL, but our machine is the 230 BL YSMC version equipped with:
  • main spindle
  • sub-spindle
  • Y-axis and C-axis (live tooling)
We would like to fully utilize the sub-spindle for part transfer and secondary operations.
Our requirements in short:
  • Support for main + sub-spindle (including spindle selection and synchronization)
  • Correct M-codes for:
    • main spindle on/off (CW/CCW)
    • sub-spindle on/off (CW/CCW)
    • spindle synchronization
    • chuck open/close for main and sub-spindle
  • Support for:
    • part transfer between main and sub-spindle
    • cut-off and pick-up
    • driven tools with C-axis and Y-axis
We are currently using the HWACHEON HI-TECH 230 AL post as a starting point, but it does not support the sub-spindle configuration of our BL YSMC machine.
If helpful, I can provide:
  • the existing AL post we are using now,
  • the machine’s G/M-code list from the controller,
  • sample NC programs generated directly from the machine tool vendor.
Could you please help with:
  • a dedicated post for HWACHEON HI-TECH 230 BL YSMC, or
  • guidance / a modified version of the existing AL post with proper sub-spindle support?
Thank you in advance for your support and any guidance.
Best regards,
Kamil
1 Comment
JLawlor_Xepot
I need the same!!!!  Same machine
