Fanuc Laser
Fanuc Laser
We have recently been working on developing a post processor for Laser machines with a Fanuc control. We have finished development and have now released the post as BETA.
If you would be interested in testing this post and providing feedback on it's performance, it can be downloaded
from >>HERE<<
13 Comments
I have tried to download this post and it will not let it work in fusion 360?
GeorgeRoberts
Thanks for the feedback. Are you receiving an error message? If so, please could you post it here?
Many thanks
I just keeps saying its not a supported file type
GeorgeRoberts
The post processor is a CPS file which can be selected inside of the post dialog window. You will not be able to open the .CPS file as a document inside of Fusion / HSM
The post seems to be generating code that does not match the geometry of the part. I have used both in computer and in control to adjust the code with no luck. I also changed the kerf size with no luck. Below is a small peice of code to cut a .250 wide slot and you can see the I.0.1324 when is shout be I0.1250
G01X0.4368Y0.5953F#148
G03X0.4076Y0.5246I0.0707J-0.0707
G01Y0.275
G03X0.6725I0.1324J0
G01Y0.76
G03X0.4076I-0.1325J0
G01Y0.5246
G01Y0.275
G03X0.6725I0.1324J0
G01Y0.76
G01Y0.5246
GeorgeRoberts
Thanks for the reply. Please could you share a copy of the file you used to create this?
Many thanks
Here is the part file.
Have you guys gotten any closer on this Fanuc post
GeorgeRoberts
Hi @anderson_matthew7.
I can't seem to see the part file you attached. Please could you email it to [email protected]?
larnold63AZV
Community Visitor
Just downloaded and we are working on setting up an older Fanuc Laser.
We also have some Waterjet machines and the download indicates this may also work with Waterjets.
I will try to report back.
tlemasterPPX92
Observer
Did you ever build a final version of this post processor?
Is there anywhere we can download it?
tlemasterPPX92
Observer
No answer so far. But I did find out that older Amada Lasers use the same fanuc laser controller.
Amada post processor if anyone is looking for a possible solution. Will update results once we test out.
https://cam.autodesk.com/hsmposts?p=amada_laser
@GeorgeRoberts
