Bystronic Laser
Bystronic Laser
We have recently been working on a post processor for Bystronic Laser machines and have now released the post as BETA.
If you would be interested in testing this post and providing feedback on it's performance, it can be downloaded
from >>HERE<<
8 Comments
albendea2
La Linea de Incio no aparecce
[START OF FILE]
Las funciones M04 Laser ON y M05 Laser OFF tiene que ir al final de una linea de G01..G02,G03
N1002G1Y20M04
N1G29X260Y240P1H100A1  define nombre de la pieza o subrutina
N2G52X10Y190L1O0             donde va la pieza, llamada a subrutina
G99                                          fin de programa principal
G28X55Y50L1P1                    Inicio Subrutina
G98                                         Fin subrutina
&                                              FIN PROGRAMA
[END OF FILE]
{INITIALIZE CUT PARAMETERS}
(<NcpProgram Version="1.0" Units="{UNITS}" CNCVersion="P8100">)
(<MaterialInfo {MI 3} {MI 4}/>)
  (<ProcessInfo CutTechnology="Laser" Clamping="False" ProcessGas="{PROCESSGAS}" CuttingHead="{CUTTINGHEAD}" Additional="-"/>)
  (<Plan JobCode="{ROOT FILE NAME}" Label="{ROOT FILE NAME} {NEST NUMBER}">)
Has there been any updates for this post? We are getting a Bystronic laser and plan on using HSM and the Nesting Utility. I noticed there is no "%" symbol only on the first line of code which Bystronic states it must have.
albendea2
FUNCIONA? NO CREO, el programa byview de bystronic no carga las piezas, y si arreglas el postproceador
los circulos no los hace bien, no aparecen ataques etc... , el postprocesador no es mas que una demo un ejemplo.
no se porque HSM lo ha subido sin testearlo.
Por el contrario aparacen modificaciones y actualizaciones
no entiendo
Howdy,
I know I am a little late to this party but I am working with a Bystar 3015, 2003 model and Bylaser 4000 also from 2003.
I downloaded the POST from the Fusion 360 library, and when I try to run the following program...
(Test Blocks 1001-orignal)
G29X48Y23.75PTest Blocks 1001-orignalH1
(IMPERIAL)
G70
(2D Profile1 2)
G10
G0X21.9606Y-9.0489
G1X21.9538Y-9.0529M4
G41
G1X21.9932Y-9.1211
G1X21.9952Y-9.1245
G1X21.9961Y-9.125
G1X22
G3Y-8.625I0J0.25
G3Y-9.125I0J-0.25
G1X22.0039
G1X22.0049Y-9.1245
G1X22.0462Y-9.0529
G1X22.0394Y-9.0489
G40
G1M5
G0Y-9.7636
G1X22.0462Y-9.7596M4
G41
G1X22.0068Y-9.6915
G1X22.0049Y-9.688
G1X22.0039Y-9.6875
G1X22
G3X21.8125Y-9.875I0J-0.1875
G3X22.1875I0.1875J0
G3X22Y-9.6875I-0.1875J0
G1X21.9961
G1X21.9952Y-9.688
I get "Line 3: parse error (Token: T)"
I just started using this machine so not familiar with any of its quirks, and there seems to be no documentation available for it other than the operators manual I have which does not cover this.
albendea2
line 3: G10
falta herramienta: G10S0
ksdmotion
Community Visitor
Hello Jorge, I have a Bystronic bystar 3015 co2 3500w laser, I want to make a post-processor to use in vectric's cut2d software, vectric has a post generator but I need information about the bystronic control.
Thank your
rodrigogomes51
I'm having the same problem on Bystar 3015. I was analyzing the gcode file (.LLC). There is a huge difference between the functional file. Look below:
( LASER BYSTRONIC )
( NoPGM.: 0 by ALMA )
( PANOPLIE: output.n01 )
( MAT.: Mild steel EP.: 3 mm )
( DIMENSIONS: 325X1200X3 mm )
N1G29X325Y1200P1H1
N2G51X0Y0
N3G17
N4G52X0Y0L100
N5G52X84.35Y36.08L1O0
N6G52X84.35Y181.11L1
N7G52X84.35Y326.13L1
N8G52X84.35Y471.15L1
N9G52X84.35Y616.17L1
N10G52X84.35Y761.19L1
N11G52X84.35Y906.21L1
N12G52X75Y1130.13L2
N13G52X225.09Y1086.13L3
N14G52X225.09Y941.11L4
N15G52X225.09Y796.08L4
N16G52X225.09Y651.06L4
N17G52X225.09Y506.04L4
N18G52X225.09Y361.02L5
N19G52X225.09Y216L5
N20G52X225.09Y70.98L5
N21G99
(P1)
N22G28X140Y143.2L1P1
N23G41
N24G1X0.4Y-1.67M4
N25G3X1.69Y0.44R1.75
N26X-0.42Y1.74
N27X-1.71Y-0.37
N28X0.4Y-1.67R1.75
N29G1X0.17Y-0.7M5
N30G40
N31G0X-18.68Y77.79
N32G41
N33G1X-18.28Y76.12M4
N34G3X-16.98Y78.23R1.75
N35X-19.09Y79.53
N36X-20.39Y77.42
N37X-18.28Y76.12R1.75
N38G1X-18.51Y77.09M5
N39G40
N40G0X-12.5Y39.2
N41G41
N42G1X-11.8Y36.28M4
N43G3X-8.18Y34.07R3
N44X-4.48Y40.1R5
N45X-10.51Y43.79
N46X-14.21Y37.76
N47X-8.18Y34.07R5
N48X-5.96Y37.68R3M5
N49G1X-6.2Y38.66
N50G40
N51G0X-30Y112.13
N52G41
N53G1X-29.3Y109.21M4
N54G3X-25.69Y106.99R3
N55G2X58.72Y55.27R70
N56X7Y-29.14
N57X-77.41Y22.59
N58X-25.69Y106.99R70
N59G3X-23.47Y110.61R3M5
N60G1X-23.7Y111.58
N61G40
N62G98
(P2)
.... continue
there are many different g-codes if we compare with @Anonymous  and apparently the code that works separates the pieces first. I was looking for a post process that can be work!
AchimN
