Hi!
This change request is regarding synchronized tapping "on axis" with a NLX 1500sy, sub-spindle equipment machine.
An M303(Main) or M304(Sub) code must be called prior to the M329 (Synchronized tapping). The correct code should be selected based on which spindle the tapping will occur on.
Also note that the Celos freezes (no error or alarm) if the M329 code is called on the same line as anything else (expect the S for Spindle speed). No answer to that issue at this time. Other than to move the M329 down a line from the G97.
Currently Posted Example (3-22-2019):
N5(DRILL1) G330 G00 G28 U0. V0. G28 W0. M69 G54 G99 G18 M46 T0202 (TAP) M08 G00 Z4.43 X0. Y0. G00 Z4.03 G97 S244 M329 (Will freeze executing this line) G84 Z2.19 R-0.0582 P1000 F0.055556 G80 G00 Z4.43 M05 M09
Manually corrected after post:
N5(DRILL3) G330 G00 G28 U0. V0. G28 W0. M69 G54 G99 G18 M46 T0202 (TAP) M08 G00 Z4.43 X0. Y0. G00 Z4.03 M303 (Main Spindle) G97 M329 S244 G84 Z2.19 R-0.0582 P1000 F0.055556 G80 G00 Z4.43 M05 M09
Cheers,
-Aaron
