D.ELECTRON Z32 CNC Control
We are working on a generic D.ELECTRON Z32 CNC Control post processor.  We would be happy to get some feedback from you before we put it into production. Feel free to download and test this post processor and provide any feedback you might have. You can download it from the following link:
https://cam.autodesk.com/hsmposts?p=d-electron_cnc_z32
6 Comments
Hello, i have 3-axis cnc machine, CNC Pear EC32.
That machine is using old  1998y. Z32 d.electron controll.
Is this postprocessor compatible with that kind of controll unit?
Any help or reply will be helpfull, i need CAM and postprocessor for my machine.
Handwriting is not option anymore
Joseph.
bob.schultz
Hello Joseph,
It looks like the post should run your machine.  It does not output the High Speed Parameters at this time, but these can be added if necessary.
AchimN
Eurotech_2009
Observer
Hello, I used Z32 post;
Inoted some problem with G3 code (circular interpolation); in particolar on G3 command I and J are not every written !
please can you check it?
thx
Franz
bob.schultz
Hello Franz,
You can force the I and J on every circular block by adding the control:CONTROL_FORCE parameter to the IJK output variables defined at the top of the program.
// circular output
var iOutput = createOutputVariable({prefix:"I", control:CONTROL_FORCE}, xyzFormat);
var jOutput = createOutputVariable({prefix:"J", control:CONTROL_FORCE}, xyzFormat);
var kOutput = createOutputVariable({prefix:"K", control:CONTROL_FORCE}, xyzFormat);
Please let me know if this fixes your issue and we will update the library post processor.
Eurotech_2009
Observer
Copyright (C) 2012-2023 by Autodesk, Inc.
All rights reserved.
RS-274D post processor configuration.
$Revision: 44083 9bbc93e5db6952d3bd6ecce596d077ca2c467bf3 $
$Date: 2023-08-09 09:33:13 $
FORKID {1950D3FD-E395-4FA3-B81F-0A4AC2F948F4}
description = "D.ELECTRON Z32 CNC Control";
vendor = "D.ELECTRON";
vendorUrl = "https://www.delectron.it/en/#page";
legal = "Copyright (C) 2012-2023 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 45917;
longDescription = "Generic post for the D.ELECTRON Z32 CNC control.";
extension = "nc";
setCodePage("ascii");
capabilities = CAPABILITY_MILLING | CAPABILITY_MACHINE_SIMULATION;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = 1 << PLANE_XY; // allow any circular motion
// user-defined properties
properties = {
preloadTool: {
title : "Preload tool",
description: "Preloads the next tool at a tool change (if any).",
group : "preferences",
type : "boolean",
value : true,
scope : "post"
showSequenceNumbers: {
title : "Use sequence numbers",
description: "'Yes' outputs sequence numbers on each block, 'Only on tool change' outputs sequence numbers on tool change blocks only, and 'No' disables the output of sequence numbers.",
group : "formats",
type : "enum",
values : [
{title:"Yes", id:"true"},
{title:"No", id:"false"},
{title:"Only on tool change", id:"toolChange"}
value: "true",
scope: "post"
sequenceNumberStart: {
title : "Start sequence number",
description: "The number at which to start the sequence numbers.",
group : "formats",
type : "integer",
value : 10,
scope : "post"
sequenceNumberIncrement: {
title : "Sequence number increment",
description: "The amount by which the sequence number is incremented by in each block.",
group : "formats",
type : "integer",
value : 5,
scope : "post"
optionalStop: {
title : "Optional stop",
description: "Outputs optional stop code during when necessary in the code.",
type : "boolean",
value : true,
scope : "post"
separateWordsWithSpace: {
title : "Separate words with space",
description: "Adds spaces between words if 'yes' is selected.",
group : "formats",
type : "boolean",
value : true,
scope : "post"
useRigidTapping: {
title : "Use rigid tapping",
description: "Enables rigid tapping mode.",
type : "boolean",
value : false,
scope : "post"
safePositionMethod: {
title : "Safe Retracts",
description: "Select your desired retract option. 'Clearance Height' retracts to the operation clearance height.",
group : "homePositions",
type : "enum",
values : [
{title:"G53", id:"G53"},
{title:"Clearance Height", id:"clearanceHeight"}
value: "G53",
scope: "post"
homePositionX: {
title : "G53 home position X",
description: "G53 X-axis home position.",
type : "number",
value : 0,
scope : "post"
homePositionY: {
title : "G53 home position Y",
description: "G53 Y-axis home position.",
type : "number",
value : 0,
scope : "post"
homePositionZ: {
title : "G53 home position Z",
description: "G53 Z-axis home position.",
type : "number",
value : 0,
scope : "post"
// wcs definiton
wcsDefinitions = {
useZeroOffset: false,
wcs : [
{name:"Standard", format:"O", range:[1, 999]}
var gFormat = createFormat({prefix:"G", decimals:0});
var mFormat = createFormat({prefix:"M", decimals:0});
var oFormat = createFormat({prefix:"O", decimals:0});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4)});
var abcFormat = createFormat({decimals:3, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 1 : 2)});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3}); // seconds - range 0.001-1000
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createOutputVariable({prefix:"X"}, xyzFormat);
var yOutput = createOutputVariable({prefix:"Y"}, xyzFormat);
var zOutput = createOutputVariable({onchange:function () {retracted = false;}, prefix:"Z"}, xyzFormat);
var aOutput = createOutputVariable({prefix:"A"}, abcFormat);
var bOutput = createOutputVariable({prefix:"B"}, abcFormat);
var cOutput = createOutputVariable({prefix:"C"}, abcFormat);
var feedOutput = createOutputVariable({prefix:"F"}, feedFormat);
var sOutput = createOutputVariable({prefix:"S", control:CONTROL_FORCE}, rpmFormat);
// circular output
var iOutput = createOutputVariable({prefix:"I"}, xyzFormat);
var jOutput = createOutputVariable({prefix:"J"}, xyzFormat);
var kOutput = createOutputVariable({prefix:"K"}, xyzFormat);
// circular output
var gMotionModal = createOutputVariable({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createOutputVariable({}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createOutputVariable({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createOutputVariable({}, gFormat); // modal group 5 // G93-94
var gUnitModal = createOutputVariable({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createOutputVariable({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createOutputVariable({}, gFormat); // modal group 10 // G98-99
var settings = {
coolant: {
// samples:
// {id: COOLANT_THROUGH_TOOL, on: 88, off: 89}
// {id: COOLANT_THROUGH_TOOL, on: [8, 88], off: [9, 89]}
// {id: COOLANT_THROUGH_TOOL, on: "M88 P3 (myComment)", off: "M89"}
coolants: [
{id:COOLANT_FLOOD, on:8},
{id:COOLANT_MIST, on:7},
{id:COOLANT_THROUGH_TOOL},
{id:COOLANT_AIR},
{id:COOLANT_AIR_THROUGH_TOOL},
{id:COOLANT_SUCTION},
{id:COOLANT_FLOOD_MIST},
{id:COOLANT_FLOOD_THROUGH_TOOL},
{id:COOLANT_OFF, off:9}
singleLineCoolant: false, // specifies to output multiple coolant codes in one line rather than in separate lines
retract: {
cancelRotationOnRetracting: false, // specifies that rotations (G68) need to be canceled prior to retracting
methodXY : undefined, // special condition, overwrite retract behavior per axis
methodZ : undefined, // special condition, overwrite retract behavior per axis
useZeroValues : ["G28", "G30"] // enter property value id(s) for using "0" value instead of machineConfiguration axes home position values (ie G30 Z0)
machineAngles: { // refer to https://cam.autodesk.com/posts/reference/classMachineConfiguration.html#a14bcc7550639c482492b4ad05b1...
controllingAxis: ABC,
type : PREFER_PREFERENCE,
options : ENABLE_ALL
workPlaneMethod: {
useTiltedWorkplane : true, // specifies that tilted workplanes should be used (ie. G68.2, G254, PLANE SPATIAL, CYCLE800), can be overwritten by property
eulerConvention : EULER_XYZ_R, // specifies the euler convention (ie EULER_XYZ_R), set to undefined to use machine angles for TWP commands ('undefined' requires machine configuration)
eulerCalculationMethod: "standard", // ('standard' / 'machine') 'machine' adjusts euler angles to match the machines ABC orientation, machine configuration required
cancelTiltFirst : false, // cancel tilted workplane prior to WCS (G54-G59) blocks
useABCPrepositioning : true, // position ABC axes prior to tilted workplane blocks
forceMultiAxisIndexing: false, // force multi-axis indexing for 3D programs
optimizeType : undefined // can be set to OPTIMIZE_NONE, OPTIMIZE_BOTH, OPTIMIZE_TABLES, OPTIMIZE_HEADS, OPTIMIZE_AXIS. 'undefined' uses legacy rotations
comments: {
permittedCommentChars: " abcdefghijklmnopqrstuvwxyz0123456789.,=_-:", // letters are not case sensitive, use option 'outputFormat' below. Set to 'undefined' to allow any character. Set to 'undefined' to allow any character
prefix : "(", // specifies the prefix for the comment
suffix : ")", // specifies the suffix for the comment
outputFormat : "ignoreCase", // can be set to "upperCase", "lowerCase" and "ignoreCase". Set to "ignoreCase" to write comments without additional formatting
maximumLineLength : 80 // the maximum number of characters allowed in a line, set to 0 to disable comment output
maximumSequenceNumber : undefined, // the maximum sequence number (Nxxx), use 'undefined' for unlimited
supportsOptionalBlocks : false, // specifies if optional block output is supported
outputToolLengthCompensation: false, // specifies if tool length compensation code should be output (G43)
outputToolLengthOffset : false, // specifies if tool length offset code should be output (Hxx)
outputToolDiameterOffset : false // specifies if tool diameter offset code should be output for tool radius compensation (Dxx)
function onOpen() {
// define and enable machine configuration
receivedMachineConfiguration = machineConfiguration.isReceived();
if (typeof defineMachine == "function") {
defineMachine(); // hardcoded machine configuration
activateMachine(); // enable the machine optimizations and settings
if (!receivedMachineConfiguration) {
machineConfiguration.setHomePositionX(getProperty("homePositionX"));
machineConfiguration.setHomePositionY(getProperty("homePositionY"));
machineConfiguration.setRetractPlane(getProperty("homePositionZ"));
gPlaneModal.disable();
if (!getProperty("separateWordsWithSpace")) {
setWordSeparator("");
writeComment(programName);
writeComment(programComment);
writeProgramHeader();
// absolute coordinates and feed per min
writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94));
// writeBlock(gUnitModal.format(unit == MM ? 21 : 20));
validateCommonParameters();
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function cancelWorkPlane() {
function setWorkPlane(abc) {
if (!settings.workPlaneMethod.forceMultiAxisIndexing && is3D() && !machineConfiguration.isMultiAxisConfiguration()) {
return; // ignore
var workplaneIsRequired = (currentWorkPlaneABC == undefined) ||
abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z);
writeStartBlocks(workplaneIsRequired, function () {
if (!retracted) {
writeRetract(Z);
if (settings.workPlaneMethod.useTiltedWorkplane) {
onCommand(COMMAND_UNLOCK_MULTI_AXIS);
if (machineConfiguration.isMultiAxisConfiguration()) {
var machineABC = abc.isNonZero() ? (currentSection.isMultiAxis() ? getCurrentDirection() : getWorkPlaneMachineABC(currentSection, false)) : abc;
if (settings.workPlaneMethod.useABCPrepositioning || machineABC.isZero()) {
positionABC(machineABC, false);
} else {
setCurrentABC(machineABC);
if (abc.isNonZero()) {
writeBlock(machineConfiguration.isHeadConfiguration() ? formatWords(gFormat.format(117), "KA2") : formatWords(gFormat.format(118) + "N", "HR2"));
writeBlock(gFormat.format(116), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x));
if (abcFormat.getResultingValue(abc.y) != 0) {
writeBlock(gFormat.format(116), "J" + abcFormat.format(abc.y));
if (abcFormat.getResultingValue(abc.z) != 0) {
writeBlock(gFormat.format(116), "K" + abcFormat.format(abc.z));
} else {
writeBlock(machineConfiguration.isHeadConfiguration() ? formatWords(gFormat.format(117), "KA0") : formatWords(gFormat.format(118) + "E"));
writeBlock(gFormat.format(116), "KA0");
} else {
positionABC(abc, true);
if (!currentSection.isMultiAxis()) {
onCommand(COMMAND_LOCK_MULTI_AXIS);
currentWorkPlaneABC = abc;
function onSection() {
var forceSectionRestart = optionalSection && !currentSection.isOptional();
optionalSection = currentSection.isOptional();
var insertToolCall = isToolChangeNeeded("number") || forceSectionRestart;
var newWorkOffset = isNewWorkOffset() || forceSectionRestart;
var newWorkPlane = isNewWorkPlane() || forceSectionRestart;
operationNeedsSafeStart = getProperty("safeStartAllOperations") && !isFirstSection();
if (insertToolCall || newWorkOffset || newWorkPlane) {
if (insertToolCall && !isFirstSection()) {
onCommand(COMMAND_STOP_SPINDLE); // stop spindle before retract during tool change
writeRetract(Z); // retract
writeln("");
writeComment(getParameter("operation-comment", ""));
// tool change
if (tool.manualToolChange) {
onCommand(COMMAND_LOAD_TOOL);
} else {
writeToolCall(tool, insertToolCall);
startSpindle(tool, insertToolCall);
// Output modal commands here
writeBlock(gAbsIncModal.format(90), gFeedModeModal.format((machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ? 131 : 94));
// wcs
if (insertToolCall) { // force work offset when changing tool
currentWorkOffset = undefined;
writeWCS(currentSection, true);
forceXYZ();
var abc = defineWorkPlane(currentSection, true);
if (machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) {
writeBlock(machineConfiguration.isHeadConfiguration() ? gFormat.format(117) : formatWords(gFormat.format(118) + "N", "HR1"));
setCoolant(tool.coolant); // writes the required coolant codes
forceAny();
// prepositioning
var initialPosition = getFramePosition(currentSection.getInitialPosition());
var isRequired = insertToolCall || retracted || (!isFirstSection() && getPreviousSection().isMultiAxis());
writeInitialPositioning(initialPosition, isRequired);
function onDwell(seconds) {
if (seconds > 99999.999) {
warning(localize("Dwelling time is out of range."));
seconds = clamp(0.001, seconds, 99999.999);
writeBlock(gFormat.format(4), "TT" + secFormat.format(seconds));
function onSpindleSpeed(spindleSpeed) {
writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r, c) {
return [
gFormat.format(800),
"MHA" + xyzFormat.format(r),
"MHB" + xyzFormat.format(z),
"MHC" + xyzFormat.format(c)
function onCyclePoint(x, y, z) {
if (!isSameDirection(machineConfiguration.getSpindleAxis(), getForwardDirection(currentSection))) {
expandCyclePoint(x, y, z);
return;
if (isFirstCyclePoint()) {
repositionToCycleClearance(cycle, x, y, z);
// return to initial Z which is clearance plane and set absolute mode
var F = cycle.feedrate;
var P = !cycle.dwell ? 0 : clamp(0.001, cycle.dwell, 99999.999); // in seconds
switch (cycleType) {
case "drilling":
case "counter-boring":
writeBlock(
getCommonCycle(x, y, z, cycle.retract, cycle.clearance),
conditional(P, "MHT" + secFormat.format(P)),
feedOutput.format(F),
"K1"
break;
case "chip-breaking":
if (cycle.accumulatedDepth < cycle.depth) {
writeBlock(
"MHI" + xyzFormat.format(cycle.incrementalDepth),
conditional(cycle.chipBreakDistance, "MHR" + xyzFormat.format(cycle.chipBreakDistance)),
"MHL" + xyzFormat.format(cycle.accumulatedDepth),
conditional((P && !cycle.chipBreakDistance), "MHT" + secFormat.format(P)),
"K7"
break;
writeBlock(
"K2"
break;
case "deep-drilling":
writeBlock(
"MHZ" + xyzFormat.format(cycle.retract),
"K3"
break;
case "tapping":
case "left-tapping":
case "right-tapping":
writeBlock(
"MHP" + xyzFormat.format(cycle.incrementalDepth),
"MHP" + xyzFormat.format(tool.threadPitch * (unit == IN ? 25.4 : 1)),
"MHM" + (getProperty("useRigidTapping") ? "0" : "1"),
conditional(P, "MHW" + secFormat.format(P)),
"K4"
break;
case "fine-boring": // not supported
break;
case "back-boring": // not supported
break;
case "reaming":
if (feedFormat.getResultingValue(cycle.feedrate) != feedFormat.getResultingValue(cycle.retractFeedrate)) {
break;
writeBlock(
"K5"
break;
case "stop-boring":
writeBlock(
"MHS0", // no spindle orientation
"K6"
break;
case "manual-boring":
break;
case "boring":
break;
default:
} else {
if (cycleExpanded) {
// G00 move performs the cycle
if (!cycleExpanded) {
gMotionModal.reset();
xOutput.reset();
yOutput.reset();
writeBlock(gMotionModal.format(0), xOutput.format(x), yOutput.format(y));
function onCycleEnd() {
writeBlock(gFormat.format(800), "K0");
zOutput.reset();
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
// one of X/Y and I/J are required and likewise
if (pendingRadiusCompensation >= 0) {
error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
return;
var start = getCurrentPosition();
if (isFullCircle()) {
if (isHelical()) {
linearize(tolerance);
return;
switch (getCircularPlane()) {
case PLANE_XY:
writeBlock(gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), iOutput.format(cx), jOutput.format(cy), feedOutput.format(feed));
break;
case PLANE_ZX:
writeBlock(gMotionModal.format(clockwise ? 2 : 3), zOutput.format(z), iOutput.format(cx), kOutput.format(cz), feedOutput.format(feed));
break;
case PLANE_YZ:
writeBlock(gMotionModal.format(clockwise ? 2 : 3), yOutput.format(y), jOutput.format(cy), kOutput.format(cz), feedOutput.format(feed));
break;
default:
} else {
case PLANE_XY:
writeBlock(gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx), jOutput.format(cy), feedOutput.format(feed));
break;
case PLANE_ZX:
writeBlock(gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx), kOutput.format(cz), feedOutput.format(feed));
break;
case PLANE_YZ:
writeBlock(gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy), kOutput.format(cz), feedOutput.format(feed));
break;
default:
var mapCommand = {
COMMAND_END : 2,
COMMAND_STOP_SPINDLE : 5,
COMMAND_ORIENTATE_SPINDLE: 19
function onCommand(command) {
switch (command) {
case COMMAND_COOLANT_OFF:
setCoolant(COOLANT_OFF);
return;
case COMMAND_COOLANT_ON:
return;
case COMMAND_STOP:
writeBlock(mFormat.format(0));
forceSpindleSpeed = true;
forceCoolant = true;
return;
case COMMAND_OPTIONAL_STOP:
writeBlock(mFormat.format(1));
return;
case COMMAND_START_SPINDLE:
forceSpindleSpeed = false;
writeBlock(sOutput.format(spindleSpeed), mFormat.format(tool.clockwise ? 3 : 4));
return;
case COMMAND_LOAD_TOOL:
writeBlock(gFormat.format(39));
writeToolBlock("T" + toolFormat.format(tool.number), mFormat.format(6), formatComment("MANUAL TOOL CHANGE TO T" + toolFormat.format(tool.number)));
writeBlock(gFormat.format(38));
} else {
writeToolBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
writeComment(tool.comment);
var preloadTool = getNextTool(tool.number != getFirstTool().number);
if (getProperty("preloadTool") && preloadTool) {
writeBlock("T" + toolFormat.format(preloadTool.number)); // preload next/first tool
return;
case COMMAND_LOCK_MULTI_AXIS:
return;
case COMMAND_UNLOCK_MULTI_AXIS:
return;
case COMMAND_BREAK_CONTROL:
return;
case COMMAND_TOOL_MEASURE:
return;
var stringId = getCommandStringId(command);
var mcode = mapCommand[stringId];
if (mcode != undefined) {
writeBlock(mFormat.format(mcode));
} else {
onUnsupportedCommand(command);
function onSectionEnd() {
if (!isLastSection() && (getNextSection().getTool().coolant != tool.coolant)) {
if (currentSection.isMultiAxis()) {
if (machineConfiguration.isHeadConfiguration()) {
writeBlock(gFormat.format(117), "KA0");
} else {
writeBlock(gFormat.format(118) + "E");
forceAny();
function writeRetract() {
var retract = getRetractParameters.apply(this, arguments);
if (retract && retract.words.length > 0) {
if (typeof gRotationModal != "undefined" && gRotationModal.getCurrent() == 68 && settings.retract.cancelRotationOnRetracting) { // cancel rotation before retracting
cancelWorkPlane(true);
switch (retract.method) {
case "G53":
forceModals(gMotionModal, gAbsIncModal);
writeBlock(gFormat.format(53), retract.words); // retract
writeBlock(gFormat.format(54));
break;
default:
error(subst(localize("Unsupported safe position method '%1'"), retract.method));
return;
function onClose() {
writeRetract(Z);
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
writeRetract(X, Y);
writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
// >>>>> INCLUDED FROM include_files/commonFunctions.cpi
// internal variables, do not change
var receivedMachineConfiguration;
var tcp = {isSupportedByControl:getSetting("supportsTCP", true), isSupportedByMachine:false, isSupportedByOperation:false};
var multiAxisFeedrate;
var sequenceNumber;
var optionalSection = false;
var currentWorkOffset;
var forceSpindleSpeed = false;
var retracted = false; // specifies that the tool has been retracted to the safe plane
var operationNeedsSafeStart = false; // used to convert blocks to optional for safeStartAllOperations
function activateMachine() {
// disable unsupported rotary axes output
if (!machineConfiguration.isMachineCoordinate(0) && (typeof aOutput != "undefined")) {
aOutput.disable();
if (!machineConfiguration.isMachineCoordinate(1) && (typeof bOutput != "undefined")) {
bOutput.disable();
if (!machineConfiguration.isMachineCoordinate(2) && (typeof cOutput != "undefined")) {
cOutput.disable();
// setup usage of useTiltedWorkplane
settings.workPlaneMethod.useTiltedWorkplane = getProperty("useTiltedWorkplane") != undefined ? getProperty("useTiltedWorkplane") :
getSetting("workPlaneMethod.useTiltedWorkplane", false);
settings.workPlaneMethod.useABCPrepositioning = getProperty("useABCPrepositioning") != undefined ? getProperty("useABCPrepositioning") :
getSetting("workPlaneMethod.useABCPrepositioning", false);
if (!machineConfiguration.isMultiAxisConfiguration()) {
return; // don't need to modify any settings for 3-axis machines
// identify if any of the rotary axes has TCP enabled
var axes = [machineConfiguration.getAxisU(), machineConfiguration.getAxisV(), machineConfiguration.getAxisW()];
tcp.isSupportedByMachine = axes.some(function(axis) {return axis.isEnabled() && axis.isTCPEnabled();}); // true if TCP is enabled on any rotary axis
// save multi-axis feedrate settings from machine configuration
var mode = machineConfiguration.getMultiAxisFeedrateMode();
var type = mode == FEED_INVERSE_TIME ? machineConfiguration.getMultiAxisFeedrateInverseTimeUnits() :
(mode == FEED_DPM ? machineConfiguration.getMultiAxisFeedrateDPMType() : DPM_STANDARD);
multiAxisFeedrate = {
mode : mode,
maximum : machineConfiguration.getMultiAxisFeedrateMaximum(),
type : type,
tolerance: mode == FEED_DPM ? machineConfiguration.getMultiAxisFeedrateOutputTolerance() : 0,
bpwRatio : mode == FEED_DPM ? machineConfiguration.getMultiAxisFeedrateBpwRatio() : 1
// setup of retract/reconfigure TAG: Only needed until post kernel supports these machine config settings
if (receivedMachineConfiguration && machineConfiguration.performRewinds()) {
safeRetractDistance = machineConfiguration.getSafeRetractDistance();
safePlungeFeed = machineConfiguration.getSafePlungeFeedrate();
safeRetractFeed = machineConfiguration.getSafeRetractFeedrate();
if (typeof safeRetractDistance == "number" && getProperty("safeRetractDistance") != undefined && getProperty("safeRetractDistance") != 0) {
safeRetractDistance = getProperty("safeRetractDistance");
compensateToolLength = typeof compensateToolLength == "undefined" ? false : compensateToolLength;
if (machineConfiguration.isHeadConfiguration() && compensateToolLength) {
for (var i = 0; i < getNumberOfSections(); ++i) {
var section = getSection(i);
if (section.isMultiAxis()) {
machineConfiguration.setToolLength(getBodyLength(section.getTool())); // define the tool length for head adjustments
section.optimizeMachineAnglesByMachine(machineConfiguration, OPTIMIZE_AXIS);
} else {
optimizeMachineAngles2(OPTIMIZE_AXIS);
function getBodyLength(tool) {
if (tool.number == section.getTool().number) {
return section.getParameter("operation:tool_overallLength", tool.bodyLength + tool.holderLength);
return tool.bodyLength + tool.holderLength;
function getFeed(f) {
if (getProperty("useG95")) {
return feedOutput.format(f / spindleSpeed); // use feed value
if (typeof activeMovements != "undefined" && activeMovements) {
var feedContext = activeMovements[movement];
if (feedContext != undefined) {
if (!feedFormat.areDifferent(feedContext.feed, f)) {
if (feedContext.id == currentFeedId) {
return ""; // nothing has changed
forceFeed();
currentFeedId = feedContext.id;
return settings.parametricFeeds.feedOutputVariable + (settings.parametricFeeds.firstFeedParameter + feedContext.id);
currentFeedId = undefined; // force parametric feed next time
return feedOutput.format(f); // use feed value
function validateCommonParameters() {
validateToolData();
if (getSection(0).workOffset == 0 && section.workOffset > 0) {
error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
if (!section.isOptimizedForMachine() && !getSetting("supportsToolVectorOutput", false)) {
error(localize("This postprocessor requires a machine configuration for 5-axis simultaneous toolpath."));
if (machineConfiguration.getMultiAxisFeedrateMode() == FEED_INVERSE_TIME && !getSetting("supportsInverseTimeFeed", true)) {
error(localize("This postprocessor does not support inverse time feedrates."));
if (!tcp.isSupportedByControl && tcp.isSupportedByMachine) {
error(localize("The machine configuration has TCP enabled which is not supported by this postprocessor."));
if (getProperty("safePositionMethod") == "clearanceHeight") {
var msg = "-Attention- Property 'Safe Retracts' is set to 'Clearance Height'." + EOL +
"Ensure the clearance height will clear the part and or fixtures." + EOL +
"Raise the Z-axis to a safe height before starting the program.";
warning(msg);
writeComment(msg);
function validateToolData() {
var _default = 99999;
var _maximumSpindleRPM = machineConfiguration.getMaximumSpindleSpeed() > 0 ? machineConfiguration.getMaximumSpindleSpeed() :
settings.maximumSpindleRPM == undefined ? _default : settings.maximumSpindleRPM;
var _maximumToolNumber = machineConfiguration.isReceived() && machineConfiguration.getNumberOfTools() > 0 ? machineConfiguration.getNumberOfTools() :
settings.maximumToolNumber == undefined ? _default : settings.maximumToolNumber;
var _maximumToolLengthOffset = settings.maximumToolLengthOffset == undefined ? _default : settings.maximumToolLengthOffset;
var _maximumToolDiameterOffset = settings.maximumToolDiameterOffset == undefined ? _default : settings.maximumToolDiameterOffset;
var header = ["Detected maximum values are out of range.", "Maximum values:"];
var warnings = {
toolNumber : {msg:"Tool number value exceeds the maximum value for tool: " + EOL, max:" Tool number: " + _maximumToolNumber, values:[]},
lengthOffset : {msg:"Tool length offset value exceeds the maximum value for tool: " + EOL, max:" Tool length offset: " + _maximumToolLengthOffset, values:[]},
diameterOffset: {msg:"Tool diameter offset value exceeds the maximum value for tool: " + EOL, max:" Tool diameter offset: " + _maximumToolDiameterOffset, values:[]},
spindleSpeed : {msg:"Spindle speed exceeds the maximum value for operation: " + EOL, max:" Spindle speed: " + _maximumSpindleRPM, values:[]}
var toolIds = [];
if (toolIds.indexOf(section.getTool().getToolId()) === -1) { // loops only through sections which have a different tool ID
var toolNumber = section.getTool().number;
var lengthOffset = section.getTool().lengthOffset;
var diameterOffset = section.getTool().diameterOffset;
var comment = section.getParameter("operation-comment", "");
if (toolNumber > _maximumToolNumber && !getProperty("toolAsName")) {
warnings.toolNumber.values.push(SP + toolNumber + EOL);
if (lengthOffset > _maximumToolLengthOffset) {
warnings.lengthOffset.values.push(SP + "Tool " + toolNumber + " (" + comment + "," + " Length offset: " + lengthOffset + ")" + EOL);
if (diameterOffset > _maximumToolDiameterOffset) {
warnings.diameterOffset.values.push(SP + "Tool " + toolNumber + " (" + comment + "," + " Diameter offset: " + diameterOffset + ")" + EOL);
toolIds.push(section.getTool().getToolId());
// loop through all sections regardless of tool id for idenitfying spindle speeds
// identify if movement ramp is used in current toolpath, use ramp spindle speed for comparisons
var ramp = section.getMovements() & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_ZIG_ZAG) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_HELIX));
var _sectionSpindleSpeed = Math.max(section.getTool().spindleRPM, ramp ? section.getTool().rampingSpindleRPM : 0, 0);
if (_sectionSpindleSpeed > _maximumSpindleRPM) {
warnings.spindleSpeed.values.push(SP + section.getParameter("operation-comment", "") + " (" + _sectionSpindleSpeed + " RPM" + ")" + EOL);
// sort lists by tool number
warnings.toolNumber.values.sort(function(a, b) {return a - b;});
warnings.lengthOffset.values.sort(function(a, b) {return a.localeCompare(b);});
warnings.diameterOffset.values.sort(function(a, b) {return a.localeCompare(b);});
var warningMessages = [];
for (var key in warnings) {
if (warnings[key].values != "") {
header.push(warnings[key].max); // add affected max values to the header
warningMessages.push(warnings[key].msg + warnings[key].values.join(""));
if (warningMessages.length != 0) {
warningMessages.unshift(header.join(EOL) + EOL);
warning(warningMessages.join(EOL));
function forceFeed() {
feedOutput.reset();
/** Force output of X, Y, and Z. */
function forceXYZ() {
xOutput.reset();
yOutput.reset();
zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
aOutput.reset();
bOutput.reset();
cOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
forceXYZ();
forceABC();
forceFeed();
Writes the specified block.
function writeBlock() {
var text = formatWords(arguments);
if (!text) {
return;
if ((optionalSection || skipBlocks) && !getSetting("supportsOptionalBlocks", true)) {
error(localize("Optional blocks are not supported by this post."));
if (getProperty("showSequenceNumbers") == "true") {
if (sequenceNumber == undefined || sequenceNumber >= settings.maximumSequenceNumber) {
sequenceNumber = getProperty("sequenceNumberStart");
if (optionalSection || skipBlocks) {
if (text) {
writeWords("/", "N" + sequenceNumber, text);
} else {
writeWords2("N" + sequenceNumber, arguments);
sequenceNumber += getProperty("sequenceNumberIncrement");
} else {
writeWords2("/", arguments);
} else {
writeWords(arguments);
validate(settings.comments, "Setting 'comments' is required but not defined.");
function formatComment(text) {
var prefix = settings.comments.prefix;
var suffix = settings.comments.suffix;
var _permittedCommentChars = settings.comments.permittedCommentChars == undefined ? "" : settings.comments.permittedCommentChars;
switch (settings.comments.outputFormat) {
case "upperCase":
text = text.toUpperCase();
_permittedCommentChars = _permittedCommentChars.toUpperCase();
break;
case "lowerCase":
text = text.toLowerCase();
_permittedCommentChars = _permittedCommentChars.toLowerCase();
break;
case "ignoreCase":
_permittedCommentChars = _permittedCommentChars.toUpperCase() + _permittedCommentChars.toLowerCase();
break;
default:
error(localize("Unsupported option specified for setting 'comments.outputFormat'."));
if (_permittedCommentChars != "") {
text = filterText(String(text), _permittedCommentChars);
text = String(text).substring(0, settings.comments.maximumLineLength - prefix.length - suffix.length);
return text != "" ? prefix + text + suffix : "";
Output a comment.
function writeComment(text) {
if (!text) {
return;
var comments = String(text).split(EOL);
for (comment in comments) {
var _comment = formatComment(comments[comment]);
if (_comment) {
writeln(_comment);
function onComment(text) {
writeComment(text);
Writes the specified block - used for tool changes only.
function writeToolBlock() {
var show = getProperty("showSequenceNumbers");
setProperty("showSequenceNumbers", (show == "true" || show == "toolChange") ? "true" : "false");
writeBlock(arguments);
setProperty("showSequenceNumbers", show);
var skipBlocks = false;
function writeStartBlocks(isRequired, code) {
var safeSkipBlocks = skipBlocks;
if (!isRequired) {
if (!getProperty("safeStartAllOperations", false)) {
return; // when safeStartAllOperations is disabled, dont output code and return
// if values are not required, but safe start is enabled - write following blocks as optional
skipBlocks = true;
code(); // writes out the code which is passed to this function as an argument
skipBlocks = safeSkipBlocks; // restore skipBlocks value
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
pendingRadiusCompensation = radiusCompensation;
if (pendingRadiusCompensation >= 0 && !getSetting("supportsRadiusCompensation", true)) {
error(localize("Radius compensation mode is not supported."));
return;
function onPassThrough(text) {
var commands = String(text).split(",");
for (text in commands) {
writeBlock(commands[text]);
function forceModals() {
if (arguments.length == 0) { // reset all modal variables listed below
if (typeof gMotionModal != "undefined") {
if (typeof gPlaneModal != "undefined") {
gPlaneModal.reset();
if (typeof gAbsIncModal != "undefined") {
gAbsIncModal.reset();
if (typeof gFeedModeModal != "undefined") {
gFeedModeModal.reset();
} else {
for (var i in arguments) {
arguments[i].reset(); // only reset the modal variable passed to this function
/** Helper function to be able to use a default value for settings which do not exist. */
function getSetting(setting, defaultValue) {
var result = defaultValue;
var keys = setting.split(".");
var obj = settings;
for (var i in keys) {
if (obj[keys[i]] != undefined) { // setting does exist
result = obj[keys[i]];
if (typeof [keys[i]] === "object") {
obj = obj[keys[i]];
continue;
} else { // setting does not exist, use default value
if (defaultValue != undefined) {
} else {
error("Setting '" + keys[i] + "' has no default value and/or does not exist.");
return undefined;
return result;
function getForwardDirection(_section) {
var forward = undefined;
var _optimizeType = settings.workPlaneMethod && settings.workPlaneMethod.optimizeType;
if (_section.isMultiAxis()) {
forward = _section.workPlane.forward;
} else if (!getSetting("workPlaneMethod.useTiltedWorkplane", false) && machineConfiguration.isMultiAxisConfiguration()) {
if (_optimizeType == undefined) {
var saveRotation = getRotation();
getWorkPlaneMachineABC(_section, true);
forward = getRotation().forward;
setRotation(saveRotation); // reset rotation
} else {
var abc = getWorkPlaneMachineABC(_section, false);
var forceAdjustment = settings.workPlaneMethod.optimizeType == OPTIMIZE_TABLES || settings.workPlaneMethod.optimizeType == OPTIMIZE_BOTH;
forward = machineConfiguration.getOptimizedDirection(_section.workPlane.forward, abc, false, forceAdjustment);
} else {
return forward;
function getRetractParameters() {
var words = []; // store all retracted axes in an array
var retractAxes = new Array(false, false, false);
var method = getProperty("safePositionMethod", "undefined");
if (method == "clearanceHeight") {
if (!is3D()) {
error(localize("Safe retract option 'Clearance Height' is only supported when all operations are along the setup Z-axis."));
return undefined;
validate(settings.retract, "Setting 'retract' is required but not defined.");
validate(arguments.length != 0, "No axis specified for getRetractParameters().");
for (i in arguments) {
retractAxes[arguments[i]] = true;
if ((retractAxes[0] || retractAxes[1]) && !retracted) { // retract Z first before moving to X/Y home
error(localize("Retracting in X/Y is not possible without being retracted in Z."));
return undefined;
// special conditions
if (retractAxes[0] || retractAxes[1]) {
method = getSetting("retract.methodXY", method);
if (retractAxes[2]) {
method = getSetting("retract.methodZ", method);
// define home positions
var useZeroValues = (settings.retract.useZeroValues && settings.retract.useZeroValues.indexOf(method) != -1);
var _xHome = machineConfiguration.hasHomePositionX() && !useZeroValues ? machineConfiguration.getHomePositionX() : toPreciseUnit(0, MM);
var _yHome = machineConfiguration.hasHomePositionY() && !useZeroValues ? machineConfiguration.getHomePositionY() : toPreciseUnit(0, MM);
var _zHome = machineConfiguration.getRetractPlane() != 0 && !useZeroValues ? machineConfiguration.getRetractPlane() : toPreciseUnit(0, MM);
for (var i = 0; i < arguments.length; ++i) {
switch (arguments[i]) {
case X:
words.push("X" + xyzFormat.format(_xHome));
xOutput.reset();
break;
case Y:
words.push("Y" + xyzFormat.format(_yHome));
yOutput.reset();
break;
case Z:
words.push("Z" + xyzFormat.format(_zHome));
zOutput.reset();
retracted = (typeof skipBlocks == "undefined") ? true : !skipBlocks;
break;
default:
error(localize("Unsupported axis specified for getRetractParameters()."));
return undefined;
return {method:method, retractAxes:retractAxes, words:words};
/** Returns true when subprogram logic does exist into the post. */
function subprogramsAreSupported() {
return typeof subprogramState != "undefined";
// <<<<< INCLUDED FROM include_files/commonFunctions.cpi
// >>>>> INCLUDED FROM include_files/defineMachine.cpi
var compensateToolLength = false; // add the tool length to the pivot distance for nonTCP rotary heads
function defineMachine() {
var useTCP = true;
if (false) { // note: setup your machine here
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120, 120], preference:1, tcp:useTCP});
var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:0, tcp:useTCP});
machineConfiguration = new MachineConfiguration(aAxis, cAxis);
setMachineConfiguration(machineConfiguration);
if (receivedMachineConfiguration) {
warning(localize("The provided CAM machine configuration is overwritten by the postprocessor."));
receivedMachineConfiguration = false; // CAM provided machine configuration is overwritten
// multiaxis settings
machineConfiguration.setVirtualTooltip(false); // translate the pivot point to the virtual tool tip for nonTCP rotary heads
// retract / reconfigure
var performRewinds = false; // set to true to enable the rewind/reconfigure logic
if (performRewinds) {
machineConfiguration.enableMachineRewinds(); // enables the retract/reconfigure logic
safeRetractDistance = (unit == IN) ? 1 : 25; // additional distance to retract out of stock, can be overridden with a property
safeRetractFeed = (unit == IN) ? 20 : 500; // retract feed rate
safePlungeFeed = (unit == IN) ? 10 : 250; // plunge feed rate
machineConfiguration.setSafeRetractDistance(safeRetractDistance);
machineConfiguration.setSafeRetractFeedrate(safeRetractFeed);
machineConfiguration.setSafePlungeFeedrate(safePlungeFeed);
var stockExpansion = new Vector(toPreciseUnit(0.1, IN), toPreciseUnit(0.1, IN), toPreciseUnit(0.1, IN)); // expand stock XYZ values
machineConfiguration.setRewindStockExpansion(stockExpansion);
// multi-axis feedrates
machineConfiguration.setMultiAxisFeedrate(
useTCP ? FEED_FPM : getProperty("useDPMFeeds") ? FEED_DPM : FEED_INVERSE_TIME,
9999.99, // maximum output value for inverse time feed rates
getProperty("useDPMFeeds") ? DPM_COMBINATION : INVERSE_MINUTES, // INVERSE_MINUTES/INVERSE_SECONDS or DPM_COMBINATION/DPM_STANDARD
0.5, // tolerance to determine when the DPM feed has changed
1.0 // ratio of rotary accuracy to linear accuracy for DPM calculations
/* home positions */
// machineConfiguration.setHomePositionX(toPreciseUnit(0, IN));
// machineConfiguration.setHomePositionY(toPreciseUnit(0, IN));
// machineConfiguration.setRetractPlane(toPreciseUnit(0, IN));
// <<<<< INCLUDED FROM include_files/defineMachine.cpi
// >>>>> INCLUDED FROM include_files/defineWorkPlane.cpi
validate(settings.workPlaneMethod, "Setting 'workPlaneMethod' is required but not defined.");
function defineWorkPlane(_section, _setWorkPlane) {
var abc = new Vector(0, 0, 0);
if (settings.workPlaneMethod.forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) {
if (isPolarModeActive()) {
abc = getCurrentDirection();
} else if (_section.isMultiAxis()) {
forceWorkPlane();
cancelTransformation();
abc = _section.isOptimizedForMachine() ? _section.getInitialToolAxisABC() : _section.getGlobalInitialToolAxis();
} else if (settings.workPlaneMethod.useTiltedWorkplane && settings.workPlaneMethod.eulerConvention != undefined) {
if (settings.workPlaneMethod.eulerCalculationMethod == "machine" && machineConfiguration.isMultiAxisConfiguration()) {
abc = machineConfiguration.getOrientation(getWorkPlaneMachineABC(_section, true)).getEuler2(settings.workPlaneMethod.eulerConvention);
} else {
abc = _section.workPlane.getEuler2(settings.workPlaneMethod.eulerConvention);
} else {
abc = getWorkPlaneMachineABC(_section, true);
if (_setWorkPlane) {
if (_section.isMultiAxis() || isPolarModeActive()) { // 4-5x simultaneous operations
cancelWorkPlane();
} else { // 3x and/or 3+2x operations
setWorkPlane(abc);
} else {
var remaining = _section.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return abc;
setRotation(remaining);
tcp.isSupportedByOperation = isTCPSupportedByOperation(_section);
return abc;
function isTCPSupportedByOperation(_section) {
var _tcp = _section.getOptimizedTCPMode() == OPTIMIZE_NONE;
if (!_section.isMultiAxis() && (settings.workPlaneMethod.useTiltedWorkplane ||
isSameDirection(machineConfiguration.getSpindleAxis(), getForwardDirection(_section)) ||
settings.workPlaneMethod.optimizeType == OPTIMIZE_HEADS ||
settings.workPlaneMethod.optimizeType == OPTIMIZE_BOTH)) {
_tcp = false;
return _tcp;
// <<<<< INCLUDED FROM include_files/defineWorkPlane.cpi
// >>>>> INCLUDED FROM include_files/getWorkPlaneMachineABC.cpi
validate(settings.machineAngles, "Setting 'machineAngles' is required but not defined.");
function getWorkPlaneMachineABC(_section, rotate) {
var currentABC = isFirstSection() ? new Vector(0, 0, 0) : getCurrentABC();
var abc = machineConfiguration.getABCByPreference(_section.workPlane, currentABC, settings.machineAngles.controllingAxis, settings.machineAngles.type, settings.machineAngles.options);
if (!isSameDirection(machineConfiguration.getDirection(abc), _section.workPlane.forward)) {
error(localize("Orientation not supported."));
if (rotate) {
if (settings.workPlaneMethod.optimizeType == undefined || settings.workPlaneMethod.useTiltedWorkplane) { // legacy
var useTCP = false;
var R = machineConfiguration.getRemainingOrientation(abc, _section.workPlane);
setRotation(useTCP ? _section.workPlane : R);
} else {
if (!_section.isOptimizedForMachine()) {
machineConfiguration.setToolLength(compensateToolLength ? _section.getTool().overallLength : 0); // define the tool length for head adjustments
_section.optimize3DPositionsByMachine(machineConfiguration, abc, settings.workPlaneMethod.optimizeType);
return abc;
// <<<<< INCLUDED FROM include_files/getWorkPlaneMachineABC.cpi
// >>>>> INCLUDED FROM include_files/positionABC.cpi
function positionABC(abc, force) {
if (typeof unwindABC == "function") {
unwindABC(abc);
if (force) {
forceABC();
var a = machineConfiguration.isMultiAxisConfiguration() ? aOutput.format(abc.x) : toolVectorOutputI.format(abc.x);
var b = machineConfiguration.isMultiAxisConfiguration() ? bOutput.format(abc.y) : toolVectorOutputJ.format(abc.y);
var c = machineConfiguration.isMultiAxisConfiguration() ? cOutput.format(abc.z) : toolVectorOutputK.format(abc.z);
if (a || b || c) {
if (!retracted) {
if (typeof moveToSafeRetractPosition == "function") {
moveToSafeRetractPosition();
} else {
writeRetract(Z);
writeBlock(gMotionModal.format(0), a, b, c);
if (getCurrentSectionId() != -1) {
setCurrentABC(abc); // required for machine simulation
// <<<<< INCLUDED FROM include_files/positionABC.cpi
// >>>>> INCLUDED FROM include_files/writeWCS.cpi
function writeWCS(section, wcsIsRequired) {
if (section.workOffset != currentWorkOffset) {
if (getSetting("workPlaneMethod.cancelTiltFirst", false) && wcsIsRequired) {
cancelWorkPlane();
if (typeof forceWorkPlane == "function" && wcsIsRequired) {
forceWorkPlane();
writeStartBlocks(wcsIsRequired, function () {
writeBlock(section.wcs);
currentWorkOffset = section.workOffset;
// <<<<< INCLUDED FROM include_files/writeWCS.cpi
// >>>>> INCLUDED FROM include_files/writeToolCall.cpi
function writeToolCall(tool, insertToolCall) {
if (typeof forceModals == "function" && (insertToolCall || getProperty("safeStartAllOperations"))) {
forceModals();
writeStartBlocks(insertToolCall, function () {
if (!retracted) {
writeRetract(Z);
if (!isFirstSection() && insertToolCall) {
if (typeof forceWorkPlane == "function") {
forceWorkPlane();
onCommand(COMMAND_COOLANT_OFF); // turn off coolant on tool change
if (typeof disableLengthCompensation == "function") {
disableLengthCompensation(false);
onCommand(COMMAND_STOP);
writeComment("MANUAL TOOL CHANGE TO T" + toolFormat.format(tool.number));
} else {
if (!isFirstSection() && getProperty("optionalStop") && insertToolCall) {
onCommand(COMMAND_OPTIONAL_STOP);
// <<<<< INCLUDED FROM include_files/writeToolCall.cpi
// >>>>> INCLUDED FROM include_files/startSpindle.cpi
function startSpindle(tool, insertToolCall) {
if (tool.type != TOOL_PROBE) {
var spindleSpeedIsRequired = insertToolCall || forceSpindleSpeed || isFirstSection() ||
rpmFormat.areDifferent(spindleSpeed, sOutput.getCurrent()) ||
(tool.clockwise != getPreviousSection().getTool().clockwise);
writeStartBlocks(spindleSpeedIsRequired, function () {
if (spindleSpeedIsRequired || operationNeedsSafeStart) {
onCommand(COMMAND_START_SPINDLE);
// <<<<< INCLUDED FROM include_files/startSpindle.cpi
// >>>>> INCLUDED FROM include_files/coolant.cpi
var currentCoolantMode = COOLANT_OFF;
var coolantOff = undefined;
var isOptionalCoolant = false;
var forceCoolant = false;
function setCoolant(coolant) {
var coolantCodes = getCoolantCodes(coolant);
if (Array.isArray(coolantCodes)) {
writeStartBlocks(!isOptionalCoolant, function () {
if (settings.coolant.singleLineCoolant) {
writeBlock(coolantCodes.join(getWordSeparator()));
} else {
for (var c in coolantCodes) {
writeBlock(coolantCodes[c]);
return undefined;
return coolantCodes;
function getCoolantCodes(coolant, format) {
if (!getProperty("useCoolant", true)) {
return undefined; // coolant output is disabled by property if it exists
if (typeof operationNeedsSafeStart == "undefined") {
var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
var coolants = settings.coolant.coolants;
if (!coolants) {
error(localize("Coolants have not been defined."));
if (tool.type && tool.type == TOOL_PROBE) { // avoid coolant output for probing
coolant = COOLANT_OFF;
if (coolant == currentCoolantMode) {
if (operationNeedsSafeStart && coolant != COOLANT_OFF) {
isOptionalCoolant = true;
} else if (!forceCoolant || coolant == COOLANT_OFF) {
return undefined; // coolant is already active
if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF) && (coolantOff != undefined) && !forceCoolant && !isOptionalCoolant) {
if (Array.isArray(coolantOff)) {
for (var i in coolantOff) {
multipleCoolantBlocks.push(coolantOff[i]);
} else {
multipleCoolantBlocks.push(coolantOff);
var m;
var coolantCodes = {};
for (var c in coolants) { // find required coolant codes into the coolants array
if (coolants[c].id == coolant) {
coolantCodes.on = coolants[c].on;
if (coolants[c].off != undefined) {
coolantCodes.off = coolants[c].off;
break;
} else {
for (var i in coolants) {
if (coolants[i].id == COOLANT_OFF) {
coolantCodes.off = coolants[i].off;
break;
if (coolant == COOLANT_OFF) {
m = !coolantOff ? coolantCodes.off : coolantOff; // use the default coolant off command when an 'off' value is not specified
} else {
coolantOff = coolantCodes.off;
m = coolantCodes.on;
if (!m) {
onUnsupportedCoolant(coolant);
m = 9;
} else {
if (Array.isArray(m)) {
for (var i in m) {
multipleCoolantBlocks.push(m[i]);
} else {
multipleCoolantBlocks.push(m);
currentCoolantMode = coolant;
for (var i in multipleCoolantBlocks) {
if (typeof multipleCoolantBlocks[i] == "number") {
multipleCoolantBlocks[i] = mFormat.format(multipleCoolantBlocks[i]);
if (format == undefined || format) {
return multipleCoolantBlocks; // return the single formatted coolant value
} else {
return m; // return unformatted coolant value
return undefined;
// <<<<< INCLUDED FROM include_files/coolant.cpi
// >>>>> INCLUDED FROM include_files/writeProgramHeader.cpi
properties.writeMachine = {
title : "Write machine",
description: "Output the machine settings in the header of the program.",
group : "formats",
type : "boolean",
value : true,
scope : "post"
properties.writeTools = {
title : "Write tool list",
description: "Output a tool list in the header of the program.",
group : "formats",
type : "boolean",
value : true,
scope : "post"
function writeProgramHeader() {
// dump machine configuration
var vendor = machineConfiguration.getVendor();
var model = machineConfiguration.getModel();
var mDescription = machineConfiguration.getDescription();
if (getProperty("writeMachine") && (vendor || model || mDescription)) {
writeComment(localize("Machine"));
if (vendor) {
writeComment(" " + localize("vendor") + ": " + vendor);
if (model) {
writeComment(" " + localize("model") + ": " + model);
if (mDescription) {
writeComment(" " + localize("description") + ": " + mDescription);
// dump tool information
if (getProperty("writeTools")) {
if (false) { // set to true to use the post kernel version of the tool list
writeToolTable(TOOL_NUMBER_COL);
} else {
var zRanges = {};
if (is3D()) {
var numberOfSections = getNumberOfSections();
for (var i = 0; i < numberOfSections; ++i) {
var zRange = section.getGlobalZRange();
var tool = section.getTool();
if (zRanges[tool.number]) {
zRanges[tool.number].expandToRange(zRange);
} else {
zRanges[tool.number] = zRange;
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + getToolTypeName(tool.type);
writeComment(comment);
// <<<<< INCLUDED FROM include_files/writeProgramHeader.cpi
// >>>>> INCLUDED FROM include_files/onRapid_fanuc.cpi
function onRapid(_x, _y, _z) {
var x = xOutput.format(_x);
var y = yOutput.format(_y);
var z = zOutput.format(_z);
if (x || y || z) {
error(localize("Radius compensation mode cannot be changed at rapid traversal."));
return;
writeBlock(gMotionModal.format(0), x, y, z);
forceFeed();
// <<<<< INCLUDED FROM include_files/onRapid_fanuc.cpi
// >>>>> INCLUDED FROM include_files/onLinear_fanuc.cpi
function onLinear(_x, _y, _z, feed) {
xOutput.reset();
yOutput.reset();
var f = getFeed(feed);
if (x || y || z) {
var d = getSetting("outputToolDiameterOffset", true) ? diameterOffsetFormat.format(tool.diameterOffset) : "";
writeBlock(gPlaneModal.format(17));
switch (radiusCompensation) {
case RADIUS_COMPENSATION_LEFT:
writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, d, f);
break;
case RADIUS_COMPENSATION_RIGHT:
writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, d, f);
break;
default:
writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
} else {
writeBlock(gMotionModal.format(1), x, y, z, f);
} else if (f) {
if (getNextRecord().isMotion()) { // try not to output feed without motion
forceFeed(); // force feed on next line
} else {
writeBlock(gMotionModal.format(1), f);
// <<<<< INCLUDED FROM include_files/onLinear_fanuc.cpi
// >>>>> INCLUDED FROM include_files/onRapid5D_fanuc.cpi
function onRapid5D(_x, _y, _z, _a, _b, _c) {
return;
if (!currentSection.isOptimizedForMachine()) {
forceXYZ();
var a = currentSection.isOptimizedForMachine() ? aOutput.format(_a) : toolVectorOutputI.format(_a);
var b = currentSection.isOptimizedForMachine() ? bOutput.format(_b) : toolVectorOutputJ.format(_b);
var c = currentSection.isOptimizedForMachine() ? cOutput.format(_c) : toolVectorOutputK.format(_c);
if (x || y || z || a || b || c) {
writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
forceFeed();
// <<<<< INCLUDED FROM include_files/onRapid5D_fanuc.cpi
// >>>>> INCLUDED FROM include_files/onLinear5D_fanuc.cpi
function onLinear5D(_x, _y, _z, _a, _b, _c, feed, feedMode) {
error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
return;
forceXYZ();
if (feedMode == FEED_INVERSE_TIME) {
forceFeed();
var f = feedMode == FEED_INVERSE_TIME ? inverseTimeOutput.format(feed) : getFeed(feed);
var fMode = feedMode == FEED_INVERSE_TIME ? 93 : getProperty("useG95") ? 95 : 94;
writeBlock(gFeedModeModal.format(fMode), gMotionModal.format(1), x, y, z, a, b, c, f);
} else if (f) {
} else {
writeBlock(gFeedModeModal.format(fMode), gMotionModal.format(1), f);
// <<<<< INCLUDED FROM include_files/onLinear5D_fanuc.cpi
// >>>>> INCLUDED FROM include_files/initialPositioning_fanuc.cpi
* Writes the initial positioning procedure for a section to get to the start position of the toolpath.
* @Anonymous {Vector} position The initial position to move to
* @Anonymous {boolean} isRequired true: Output full positioning, false: Output full positioning in optional state or output simple positioning only
* @Anonymous {String} codes1 Allows to add additional code to the first positioning line
* @Anonymous {String} codes2 Allows to add additional code to the second positioning line (if applicable)
* @example
var myVar1 = formatWords("T" + tool.number, currentSection.wcs);
var myVar2 = getCoolantCodes(tool.coolant);
writeInitialPositioning(initialPosition, isRequired, myVar1, myVar2);
function writeInitialPositioning(position, isRequired, codes1, codes2) {
var motionCode = {single:0, multi:0};
switch (highFeedMapping) {
case HIGH_FEED_MAP_ANY:
motionCode = {single:1, multi:1}; // map all rapid traversals to high feed
break;
case HIGH_FEED_MAP_MULTI:
motionCode = {single:0, multi:1}; // map rapid traversal along more than one axis to high feed
break;
var feed = (highFeedMapping != HIGH_FEED_NO_MAPPING) ? getFeed(highFeedrate) : "";
var gOffset = getSetting("outputToolLengthCompensation", true) ? gFormat.format(getOffsetCode()) : "";
var hOffset = getSetting("outputToolLengthOffset", true) ? hFormat.format(tool.lengthOffset) : "";
var additionalCodes = [formatWords(codes1), formatWords(codes2)];
forceModals(gMotionModal);
writeStartBlocks(isRequired, function() {
var modalCodes = formatWords(gAbsIncModal.format(90), gPlaneModal.format(17));
disableLengthCompensation(false); // cancel tool length compensation prior to enabling it, required when switching G43/G43.4 modes
// multi axis prepositioning with TWP
if (currentSection.isMultiAxis() && getSetting("workPlaneMethod.prepositionWithTWP", true) && getSetting("workPlaneMethod.useTiltedWorkplane", false) &&
tcp.isSupportedByOperation && getCurrentDirection().isNonZero()) {
var W = machineConfiguration.isMultiAxisConfiguration() ? machineConfiguration.getOrientation(getCurrentDirection()) :
Matrix.getOrientationFromDirection(getCurrentDirection());
var prePosition = W.getTransposed().multiply(position);
var angles = W.getEuler2(settings.workPlaneMethod.eulerConvention);
setWorkPlane(angles);
writeBlock(modalCodes, gMotionModal.format(motionCode.multi), xOutput.format(prePosition.x), yOutput.format(prePosition.y), feed, additionalCodes[0]);
cancelWorkPlane();
writeBlock(gOffset, hOffset, additionalCodes[1]); // omit Z-axis output is desired
lengthCompensationActive = true;
forceAny(); // required to output XYZ coordinates in the following line
} else {
writeBlock(modalCodes, gMotionModal.format(motionCode.multi), gOffset,
xOutput.format(position.x), yOutput.format(position.y), zOutput.format(position.z),
hOffset, feed, additionalCodes
} else {
writeBlock(modalCodes, gMotionModal.format(motionCode.multi), xOutput.format(position.x), yOutput.format(position.y), feed, additionalCodes[0]);
writeBlock(gMotionModal.format(motionCode.single), gOffset, zOutput.format(position.z), hOffset, additionalCodes[1]);
if (isRequired) {
additionalCodes = []; // clear additionalCodes buffer
validate(lengthCompensationActive, "Tool length compensation is not active."); // make sure that lenght compensation is enabled
if (!isRequired) { // simple positioning
if (!retracted && xyzFormat.getResultingValue(getCurrentPosition().z) < xyzFormat.getResultingValue(position.z)) {
writeBlock(modalCodes, gMotionModal.format(motionCode.single), zOutput.format(position.z), feed);
forceXYZ();
writeBlock(modalCodes, gMotionModal.format(motionCode.multi), xOutput.format(position.x), yOutput.format(position.y), feed, additionalCodes);
Matrix.getOrientationFromDirection = function (ijk) {
var forward = ijk;
var unitZ = new Vector(0, 0, 1);
var W;
if (Math.abs(Vector.dot(forward, unitZ)) < 0.5) {
var imX = Vector.cross(forward, unitZ).getNormalized();
W = new Matrix(imX, Vector.cross(forward, imX), forward);
} else {
var imX = Vector.cross(new Vector(0, 1, 0), forward).getNormalized();
return W;
// <<<<< INCLUDED FROM include_files/initialPositioning_fanuc.cpi
