Add IJK Drilling Support to Posts
I tried to get this adopted here: http://forums.autodesk.com/t5/hsm-post-processor-forum/add-ijk-support-for-g83-in-haas-milling-post/...
It's quite silly given how simple this code is I think. I have been using it in both our Haas and Fadal posts and it works quite well. Here are the sections that I have added if they are helpful.
Haas:
    case "chip-breaking":
      if (cycle.accumulatedDepth < cycle.depth) {
        expandCyclePoint(x, y, z);
      } else {
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73),
          getCommonCycle(x, y, z, cycle.retract),
          //"Q" + xyzFormat.format(cycle.incrementalDepth),
	  (((cycle.incrementalDepthReduction > 0) ? "I" : "Q") + xyzFormat.format(cycle.incrementalDepth)),
	  conditional(cycle.incrementalDepthReduction > 0, "J" + xyzFormat.format(cycle.incrementalDepthReduction)),
	  conditional(cycle.incrementalDepthReduction > 0, "K" + xyzFormat.format(cycle.minimumIncrementalDepth)),
          conditional(P > 0, "P" + milliFormat.format(P)), // optional
          feedOutput.format(F)
      break;
    case "deep-drilling":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
      break;
Fadal:
      // cycle.accumulatedDepth is ignored
      if (dwell > 0) {
      } else {
        writeBlock(
          conditional(cycle.chipBreakDistance > 0, "P" + xyzFormat.format(cycle.chipBreakDistance)), //optional P value
      break;
      if (dwell > 0) {
      } else {
        writeBlock(
      break;
I think it's silly not to support peck reduction, frankly.
6 Comments
Steinwerks
Tried to post a program for the Fadal today and realized that chipBreakDistance is only available in the "Chip Breaking - Partial Retract" toolpath so I had to take out this line under Deep-drilling:
It is an option in the Fadal control though for a G83 cycle.
Voted up, even though I stole your code awhile back when you first posted to roll it into my Haas post!
It has worked great so far for me.
This is definitely a valuable addition to the stock post.  Especially when using some parabolic drills where you can hit it with 3xDia on the first peck, then reduce to 1xD for the remainder.
AchimN
Status changed to: Accepted
Steinwerks
Thanks @AchimN! Smiley Happy
AchimN
Posts are updated into the library.
Steinwerks
Thanks @AchimN!
