Add Heidenhain 145 post
Add post to support Heidenhain TNC 145.
@Anonymous please give feedback here on the IdeaStation.
Beta post available here:
https://cam.autodesk.com/posts/?p=heidenhain_145
Requires careful testing.
1. Check output for drilling cycles.
2. Check RL, RR, R0 output.
3. And everything else 🙂
You can also compare output for the 155 post available here:
https://cam.autodesk.com/posts/?p=heidenhain_155
7 Comments
Yesterday I was trying this post to realy late night... I found two problems so far.
1. sometimes missing coordinate (probably if it's value = 0).
Example:
1 TOOL DEF 1 L+0,000 R+5,000
2 L Z+0,000 R0 F9999 M
3 STOP M00
4 TOOL CALL 1 Z S1000
5 L X+8,481 Y+17,434 R0 F9999 M13
6 L Z+15,000 R0 F9999 M
7 L Z+5,000 R0 F9999 M
8 L Z+1,000 R0 F1000 M
9 L Z-5,000 R0 F1000 M
10 CC X+10,000 Y+0,000
11 C X+24,658 Y+9,560 DR- R0 F1000 M
12 CC X+10,000 Y+0,000
13 C X+27,500 Y+0,000 DR- R0 F1000 M
14 CC X+10,000 Y+0,000
15 C X+0,000 Y-14,361 DR- R0 F1000 M
16 CC X-10,000 Y+0,000
17 C Y+14,361 DR- R0 F1000 M Here, there should be X+0,00 before Y, otherwise TNC will not accept program.
18 CC X+10,000 Y+0,000
19 C X+8,481 Y+17,434 DR- R0 F1000 M
20 L Z+15,000 R0 F9999 M
21 L Z+0,000 R0 F9999 M
22 STOP M00
Without " X+0,000" TNC gives error. It needs 2 coordinates, even if X = 0.
Adding it manually - makes program works perfect.
2. milling full circle gives wrong command:
10 CC X+0,000 Y+0,000
11 CP PR+55,000 IPA-360 DR- F1000 M
According to the instruction from Heidenhain it schould look like this:
11 C X+... Y+... DR+ RR F1000 M
Making for example 3/4 of the circle works fine. Maybe not how instruction says - but works:)
AchimN
Thanks for your feedback.
We have updated the post regarding the arc issues, so please download and test it again.
al.whatmough
zebb.guy
Hi all this is great and mostly working so far but i have a problem with Linear interpolation...
4 TOOL CALL 2 Z S2500
5 L X-58,349 Y+81,957 R0 F9999 M13 - This is fine
8 L Z-4,920 R0 F800 M
9 L X-58,345 Y+81,950 Z-5,050 R0 F800 M - Its giving three coordinates (Controller only allows two)
10 L X-58,332 Y+81,930 Z-5,178 R0 F800 M
11 L X-58,312 Y+81,897 Z-5,303 R0 F800 M
12 L X-58,283 Y+81,852 Z-5,422 R0 F800 M
13 L X-58,247 Y+81,795 Z-5,534 R0 F800 M
14 L X-58,203 Y+81,727 Z-5,636 R0 F800 M
15 L X-58,154 Y+81,650 Z-5,728 R0 F800 M
16 L X-58,099 Y+81,563 Z-5,809 R0 F800 M
17 L X-58,039 Y+81,469 Z-5,876 R0 F800 M
18 L X-57,975 Y+81,369 Z-5,930 R0 F800 M
19 L X-57,908 Y+81,264 Z-5,969 R0 F800 M
20 L X-57,839 Y+81,155 Z-5,992 R0 F800 M
21 L X-57,769 Y+81,046 Z-6,000 R0 F800 M
Im no expert is there something i could be doing wrong?
fonsecr
The post could be modified to discard the Z coordinate. But this is really not what you want when the toolpath actually has 3D motion like in your case.
So first thing to check is that you actually generate toolpath that only moves in XY and not XYZ at the same time. You should be able to adjust the linking and ramping settings normally. I assume you use 2D Contour and 2D Pocket. E.g. if your CNC cannot do helical ramps then you need to use a different approach.
zebb.guy
Hi i've been using the TNC145 post processor , i have an issue with 2D pockets ....
So i'm not using Helix i'm Plunging and command lines don't seem right.
For example i plunged down as i would expect to but i still get this in the command lines with 3 coordinates.
The TNC145 controller only accepts 2 coordinates (L) see red below
1 TOOL DEF 2 L+0,000 R+6,000
2 STOP M00
3 TOOL CALL 2 Z S2500
4 L X+79,800 Y+76,000 R0 F9999 M13
5 L Z+15,000 R0 F9999 M
6 L Z+5,000 R0 F9999 M
7 L Z-3,500 R0 F333 M
8 CC X+81,700 Y+76,000
9 C X+83,600 Y+76,000 DR+ R0 F800 M
10 CC X+76,000 Y+76,000
11 C X+68,400 Y+76,000 DR+ R0 F800 M
12 CC X+81,700 Y+76,000
13 C X+95,000 Y+76,000 DR+ R0 F800 M
14 CC X+76,000 Y+76,000
15 C X+57,000 Y+76,000 DR+ R0 F800 M
16 CC X+76,000 Y+76,000
17 C X+95,000 Y+76,000 DR+ R0 F800 M
18 CC X+92,467 Y+76,000
19 C X+91,949 Y+78,480 DR+ R0 F800 M
20 L X+80,317 Y+76,053 Z-3,500 R0 F800 M
21 CC X+79,800 Y+78,533
22 C X+79,800 Y+76,000 DR- R0 F800 M
23 L Z-7,000 R0 F333 M
24 CC X+81,700 Y+76,000
25 C X+83,600 Y+76,000 DR+ R0 F800 M
26 CC X+76,000 Y+76,000
27 C X+68,400 Y+76,000 DR+ R0 F800 M
28 CC X+81,700 Y+76,000
29 C X+95,000 Y+76,000 DR+ R0 F800 M
30 CC X+76,000 Y+76,000
31 C X+57,000 Y+76,000 DR+ R0 F800 M
32 CC X+76,000 Y+76,000
33 C X+95,000 Y+76,000 DR+ R0 F800 M
34 CC X+92,467 Y+76,000
35 C X+91,949 Y+78,480 DR+ R0 F800 M
36 L X+80,317 Y+76,053 Z-7,000 R0 F800 M
37 CC X+79,800 Y+78,533
38 C X+79,800 Y+76,000 DR- R0 F800 M
39 L Z-10,500 R0 F333 M
40 CC X+81,700 Y+76,000
41 C X+83,600 Y+76,000 DR+ R0 F800 M
42 CC X+76,000 Y+76,000
43 C X+68,400 Y+76,000 DR+ R0 F800 M
44 CC X+81,700 Y+76,000
45 C X+95,000 Y+76,000 DR+ R0 F800 M
46 CC X+76,000 Y+76,000
47 C X+57,000 Y+76,000 DR+ R0 F800 M
48 CC X+76,000 Y+76,000
49 C X+95,000 Y+76,000 DR+ R0 F800 M
50 CC X+92,467 Y+76,000
51 C X+91,949 Y+78,480 DR+ R0 F800 M
52 L X+80,317 Y+76,053 Z-10,500 R0 F800 M
53 CC X+79,800 Y+78,533
54 C X+79,800 Y+76,000 DR- R0 F800 M
I would imagine it should be something like....
34 L Z-7.000 R0 F333 M
36 L X+80,317 Y+76,053 R0 F800 M
let me know what you think ?
zebb.guy
Hi
I would like to modify the post as i don't see the 3D motion in those command lines.
Z is already in this position so even with the lines left in we would still only have movement on  X/Y axis.
43 C X+68,400 Y+76,000 DR+ R0 F800 M                No Z commands here
