Working instructions sorting
Hi, it would be useful that working instructions assigned to an operation could be sorted manually and not alphabetically (or to have both options). When two or more instructions are assinged for a single operation, they are shown alphabetically by default, but technicians do not need to now which instruction goes first, the instructions should be the guide for them. Sorting them manually would be useful for us, thank you!
2 Comments
andrade_david
Hey @aalmagroTJ9YP
Thanks for this suggestion! It is already under review, meaning we are checking how feasible it is to implement it in the system. My vision is that the work instructions get saved in the same order that you associate to the operation.
So if you associate instruction D, then instruction B, that will be always the order - regardless of the code of the instructions.
Let me know if you have any further comments
andrade_david
Status changed to: Accepted
Hello @aalmagroTJ9YP, I've marked this idea as accepted, meaning we're expecting to work on it and make it available in the system. Thanks!
