Show only
Search instead for
I'm marking this idea as Gathering SUpport because after analyzing it further a proper implementation would require us to trigger the production_updated webhook when an event that changes that calculated field is changed (such as a punch clock record, downtime record, or shift), making the implementation unfeasible for the near future.
As we get more votes, we will keep prioritizing it.
On a side note, in the second version of Fusion Operations API you can find this endpoint for retrieving a production record by id (which includes the timeSpent attribute that you are looking for). Therefore, you can get the same outcome if after getting a production_created webhook you query the API to get the timeSpent for that record.
