Show only
Search instead for
My workers rely heavily on PDF files while producing, to see the step specifications and instructions in general. They are also required to fill a checklist when checking out the production, to capture several data points in the process.
In this process of checking out the workers find it hard to fill the checklist, because some of the data they need is on the PDF. Fusion Operations doesn't allow us to visualize both at the same time, and every time workers leave the checklist screen the data they entered is lost. Having an option to navigate between these two (and others, such as work instructions and the BoM) would be highly beneficial.
This is a good idea, also, related to this, I posted another suggestion:
We can see the 'cycle time/work time' while we are in the Worker screen, but once you insert production (say, for example, just to fill in some data of the components, not because the operation is done) you cannot see the cycle time/work time unless you get out of the production screen. In that case, you lose the data.
It would be really helpful being able to see the time whether you are in the worker screen or you inserted production.
Another possibility is not losing the data, having the option of not just Cancel insert production but also EXIT (without losing data previously registered).
