Inventory Count improvements
If we perform an inventory count with a positive deviation, the receiving inventory movement won't have an associated cost, leading to incorrect inventory valuation. Expected would be to consider defined product unit cost or product average cost.
Also, when performing the inventory count in the tablet there is a misleading "Is Empty" button available when selecting the product. However, this just jumps the tablet selection and does not create inventory movements to zero out the inventory in the selected warehouse.
Finally, it always asks the counted lot, even if we are not using this feature.
2 Comments
andrade_david
Status changed to: Gathering Support
Thank you for pointing out all these suggestions, @m_casal
nickV7AL5
I agree very much with this suggestion. Both the positive deviation needing a cost as well as if a location is marked empty, it needs to zero out all the products in that location.
An idea for positive deviation's cost would be to use the average unit cost (if there is existing inventory) or prompt for a defined cost if there is no existing inventory to pull an average unit cost from.
