Incorrect Date Sorting in Production Schedule
I've identified a bug in the way dates are sorted in our production schedule view.
Problem Description: When attempting to sort production orders by the "START DATE" or "DUE DATE" columns, the sorting logic appears to be text-based (alphabetical) rather than chronological. This results in an incorrect order that does not reflect the actual timeline.
Steps to Reproduce:
  1. Navigate to the production schedule for any machine (e.g., Machine: WP-0001).
  2. Click the sort arrow on the "START DATE" column header.
  3. Observe the resulting order of the entries.
Expected Behavior: The production orders should be sorted chronologically. For example, an ascending sort should list them from the earliest date to the latest date (e.g., 16/09, 23/09, 29/09).
Actual Behavior: The list is sorted as if the dates were text strings. As shown in the attached screenshot, the order is 29/09, 16/09, 23/09. This is because the system is sorting by the first digit of the day ('1', then '2'), instead of the value of the entire date.
Thank you for your assistance.
4 Comments
andrade_david
Status changed to: Archived
Hello @NedyalkoDemirev
I'm marking this as archived because this is a glitch, that must be reported to the customer support team (available on the chat button, on the bottom right corner of the screen). By coincidence, the problem has already been reported by other customers, and it's being fixed at the moment.
When the fix is available I will let you know
andrade_david
This glitch has been fixed today. Now the scheduling views always sort by start date, from oldest to latest. The sorting on the columns has been removed.
You can check the latest improvements in this page: https://help.fusionoperations.autodesk.com/en/articles/10058432-release-notes
NedyalkoDemirev
Thank you! I can confirm that sorting is now working as expected.
andrade_david
Thank you for confirming it 💪
