Disable option for Downtime reason codes
Currently we don't have a option to disable the downtime reason codes. There is a way to avoid to appear in the worker menu interface but in the backoffice interface we have the complete list. We want to add the "disable" feature that we have in other modules of Fusion Operations so we can filter the downtime reason codes with that parameter.
1 Comment
andrade_david
Status changed to: Gathering Support
Hi @m_valenzuelaKSRP4
Thank you for posting your idea. I understand the problem you're facing, and indeed the disabling of entities is a commonly used approach in the system. I've marked it as gathering support.
On a side note, it is possible to hide the downtime reason code after selecting a machine by dissociating it on the "reason codes" dropdown. It is also possible to hide the downtime reason code after selecting the worker by unchecking the option "reason code for workers". However, this implies changing the downtime reason code settings - making indeed the disabling a cleaner solution.
