Just about every day, a worker makes a mistake when logging a production record in Fusion Operations. For example
Currently, when this happens, the worker has to come to management and they need to manually open the production record on the back end and fix it. I would like to propose a new feature that allows a worker to submit a "proposed correction". It could be an option when they are closing a production record, or there could also be a button on the tablet mode that says "Submit Correction". They would then see a list of their recent production records and they could click the one to correct.
Inside the module, they have access to propose changes to the fields in the production order and include any relevant notes.
Example: change end time from 8:00 pm to 5:00 pm (forgot to clock out when I left work)
The list of proposed changes would go into a queue that can be reviewed by management and they can click "Approve" or "Deny", adding notes. You could also set parameters to auto-accept certain types of changes if that were desired by the company. It would be nice to have an alert email that is sent to management, telling them to review the proposed edit. This would save a lot of time and streamline the process. Thanks
