Allow to change operation's cycle time and quantity ratios via API
Fields in the Product API are available to retrieve the validity period of an operation, but unfortunately they cannot be added new times via API.
Indeed, the operations.task-durations.validSince field is populated by default with the operation's creation date. And the operations.task-durations.validUntil field is populated by default with the value "Always".
We need to define that an operation has now a different cycle time, and we cannot make that change on the API unless we change the existing cycle time, which will impact historical data.
4 Comments
andrade_david
Status changed to: Gathering Support
Thank you for your idea, @jeremy_febvey. I've marked it as gathering support.
andrade_david
andrade_david
Status changed to: Accepted
andrade_david
Hello @jeremy_febvey
I'm happy to announce that this idea has been implemented! You can find the documentation here, and release notes updated here.
