Add an option of "Facility" on the Maintenance orders types
Currently, on the maintenance order creation interface we have the option to select between preventive or corrective maintenance, we used these options to make the maintenance orders when a machine is down due to a malfunction, however, there are times that the machine have to be stop by other reasons related to the facility issues.
Could we add a third option "Facility" to the types of maintenance?
This will allow us to track better the cause of failures and how they were addressed, therefore there will be an increase on the understanding of how the facility factors affect the machines performance and know if there is something relevant to be addressed or fixed.
Otherwise, as we are doing right now, we have to get deep into the reports to know the details of the maintenance orders, thus is causing us to spent a lot of time searching the causes of the maintenance orders therefore we have a big time consuming waste.
2 Comments
andrade_david
Hello @m_valenzuelaKSRP4 , thank you for your idea!
Can you share one example of "facility issues" that you've faced? I'm asking this because despite having this characteristic they may still be considered as "preventive" or "corrective". I would like to understand better the problem so that perhaps another solution could be considered, such as having the possibility to have additional configurable fields on maintenance orders, in which additional information could be provided (specifying for example the facility factor in that maintenance order field).
Status changed to: Gathering Support
