Add ability to Select Parameters during Inventory Count
While adding products to our inventory using inventory count, there is not currently a way to select a specific parameter. In our case, we use parameters to tell what material a product is made of since we have several options and unfortunately are now unable to accurately use the inventory count to inventory them.
2 Comments
haley_stump
Actually this relates to keeping inventory with parameters at all, not just count. We just realized that there is not any record of what material parameter is used in the inventory which makes that entire parameter useless.
andrade_david
Status changed to: Gathering Support
Hello @haley_stump , thank you for bringing this suggestion to the ideas board. This feature indeeds prevents you from using Inventory Counts and variable parameters.
We support exporting tracking inventory by variable parameters (when exporting the inventory you can select the option "Parameters"). We do not support however selecting the variable parameters when making consumptions on the mobile app.
