Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Why this error when trying to create a CAM setup?
4 REPLIES 4
tgioiosa
244 Views, 4 Replies
What does this error mean and how do I stop it? I'm trying to create a CAM setup and it won't let me pick this machine I created.  Is an actual machine model required?
Thanks for any tips!
4 REPLIES 4
Drewpan
in reply to: tgioiosa
According to the latest fusion update video, there is a new feature that allows you to load a model of the machine so
that you can check for collisions with the cutting head with parts of the machine or the part due to the geometry the
cutting head needs to be at to make a cut.
This looks like an error related to that. I think that there are only limited models available in the library to do this
but that will change as more manufacturers create a model and pass it on to AutoDesk.
You should be able to just hit ok and do what you want, you will just not have that functionality available.
I don't think it is a critical error but if it is then it will be an AutoDesk fix.
Cheers
Andrew
HughesTooling
No you don't need to have a machine model. Can't tag Seth at the moment for help as the website's being unhelpful again!
Mark Hughes
Owner, Hughes Tooling
seth.madore
Could you share your Fusion file and the machine you've created?
Seth Madore
tgioiosa
I sorted it out. Apparently I had entered in a machine model name in the "model" tab of the machine definition by mistake, and that model didn't exist. Removing the name and leaving the model 'empty' makes the error disappear!
Technology Administrators
