I have created a hex model for stock, but when I run Simulate to watch the machining it shows square stock. Why?
edit: I just tried relative round stock and it also shows up as square....
Solved by utekcnc. Go to Solution.
I found out my problem. Under "Stock" in the simulate window I had Fast (3 axis) chosen under mode. I'm not sure how that happened. thank you
It does seem that the default view got set back to Fast -3 Axis-
However, it should now retain that setting and persist through sessions
