Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
what would be the best 4 axis tool paths
3 REPLIES 3
coryharris323
254 Views, 3 Replies
i have been asked to machine a this one of a kind motorbike crankshaft for a customer that someone else had started then pulled the pin on what i am after is the best best 4th axis paths or operations to machine this we will be buying some tooling for this  job either a 14mm or 16mm tool that will give me around 100mm tool length
cheers for the help
cory
3 REPLIES 3
porsbym
in reply to: coryharris323
You can use the Rotary strategy for finishing, and few indexed Adaptive Clearing for roughing.
coryharris323
in reply to: porsbym
will rotary tool path do cyclic machining or will i need to set the job up on the centre line of the bearing journal. By indexed adaptive paths do you mean set the machine up at 0 degrees let it work as a 3 axis machine then rotate on the 4th axis 180 and let it machine the second half
seth.madore
Yes, it will be cyclic machining. There are other shops that are using Rotary for the exact same purpose; crankshafts!
And yes; regarding the roughing; use Tool Orientation and divide the roughing up into quadrants. You can go 0-90, 90-180 etc etc, or break into 3 equal chunks, whatever is best for your needs and your tooling
Seth Madore
