Vertical slot in a cylinder, undercut operation.
ea425019
ea425019
I can accomplish this undercut with a 3d pocket move, but it, and most other toolpath options cause lateral moves to reoccur.  The part shown is representative of a more complex device I am milling.
I specifically need:
1. Enter cylinder, go to side, plunge, exit.
2. Preferably do this with a threadmill, it's geometry is well suited for this in acetal plastic, a lollipop endmill or slotting mill often don't fit due to undercut reach and/or diameter.
#1  will yield a better surface finish for me, and save time.
I did try a 'form mill' which was my threadmill of choice, but I can't seem to be getting it. Any ideas?
Thanks, Eric
a.laasW8M6T
Hi
I think the best way will be to drive it with a sketch and the Trace toolpath
You will have to adjust the sketch to get the tool to go where you want but its still easier than trying to get a 3D toolpath to do what you want
ea425019
That is cleaver and works for me, it worked in simulation, I think it's good.
It remains a bit convoluted, and Fusion could made advancements to:
1. allow threadmills to do milling (specific prohibition exists)
2. do vertical plunge undercuts organically.
That said, I appreciate your help.
a.laasW8M6T
I agree it not ideal but its a relatively niche application.
I have done similar undercuts with flow and an endmill but was able to tilt the part
