Contour tool path cutting on center line
retepmahnob
retepmahnob
I have a basic model that has a solid with a curved end that was formed using a spline/extrude.
With I try to use CAM to do a 2D contour it is cutting using the center line of  the outside.
I must have something stupid set,. but cannot see.
See the only setup in the attached file
a.laasW8M6T
Hi
There is nothing attached to your post.
Its possible that you may have turned the Compensation Type to "OFF"
It should typically be "In computer"
retepmahnob
Don't know what happened to the attachment, but you are right. Somehow set this to the default
