Fusion Manufacture
using rotary toolpath
2 REPLIES 2
coryharris323
285 Views, 2 Replies
i am using a rotary tool path to machine a crankshaft the problem i am having is that it is maching somthing that should be concentric .5mm out on concentricity can any see what i have done wrong
2 REPLIES 2
jack.holmes
in reply to: coryharris323
Hi @coryharris323 ,
It looks like it was possibly down to your WCS being slightly off centre. In the attached project I have changed this in the Setup by simply selecting the edge of the shaft which has shifted it slightly. Before it seems to be referencing a sketch which is slightly out of line.
Let me know if this sorts out what you needed.
Jack Holmes
Machine Data & Process Insights
Technical Consultant
Autodesk, Ltd.
Talbot Way, Small Heath Business Park
Birmingham, B10 0HJ, UK
www.autodesk.com
coryharris323
in reply to: jack.holmes
thank you I knew there was something I just couldn't see it. It is referencing the stock that was supplied so I have moved that to be on the center line I have ad to adjust the stock position a few times to get what some else had started to clean up I have  obviously got it off center at some stage.
