Hey everyone,
I can not figure out why the fanuc turning post processor will not let me post drilling operations. Using the Haas or Siemens post works fine.
This is the log file I am getting
Information: Configuration: Generic FANUC Turning Information: Vendor: Fanuc Information: Posting intermediate data to 'C:\Users\michael\AppData\Local\Fusion 360 CAM\nc\6000.nc' Information: Total number of warnings: 1 Error: Failed to post process. See below for details. ... Loading locale from 'C:\Users\michael\AppData\Local\Autodesk\webdeploy\production\1c8eda3d042f236f121d6fb4e850f0621b6f700b\Applications\CAM360\Data\Translations\german_de.xml' Code page changed to '1252 (ANSI - Lateinisch I)' Start time: Friday, December 16, 2016 3:16:10 PM Loading locale from 'C:\Users\michael\AppData\Local\Autodesk\webdeploy\production\1c8eda3d042f236f121d6fb4e850f0621b6f700b\Applications\CAM360\Data\Posts\common.de.lang' Code page changed to '20127 (US-ASCII)' Post processor engine: 4.2.1 41279 Configuration path: C:\Users\michael\AppData\Local\Autodesk\webdeploy\production\1c8eda3d042f236f121d6fb4e850f0621b6f700b\Applications\CAM360\Data\Posts\fanuc turning.cps Include paths: C:\Users\michael\AppData\Local\Autodesk\webdeploy\production\1c8eda3d042f236f121d6fb4e850f0621b6f700b\Applications\CAM360\Data\Posts Configuration modification date: Friday, December 16, 2016 12:25:20 PM Output path: C:\Users\michael\AppData\Local\Fusion 360 CAM\nc\6000.nc Checksum of intermediate NC data: 3c4e701d00a75271c882ac3fc29c2767 Checksum of configuration: aaa41c59a1fc78758c80f894df5d2667 Vendor url: http://www.fanuc.com Legal: Copyright (C) 2012-2016 by Autodesk, Inc. Erzeugt von: Fusion 360 CAM 2.0.2604 ... Warnung: Work offset has not been specified. Using G54 as WCS. Fehler: Unsupported drilling orientation. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Fehler: Failed to execute configuration. Stop time: Friday, December 16, 2016 3:16:10 PM Post processing failed.
Any idea with that?
Solved by HughesTooling. Go to Solution.
There was a problem a while ago where the Fanuc lathe post output a G17 for all drill ops, 2 axis lathes would just error and not accept a G17 in the code. Looking at the updated post it looks like the G17 line has just been commented out, the problem is this leaves the current plane as undefined so the post fails.
Are you using a 2 axis lathe or mill turn.
I modified a post for someone else and changed the G17 to G18 and that seem to work, see here.
Mark
Edit. Used wrong link.
Mark Hughes
Owner, Hughes Tooling
Hi Mark,
deleting the two // for the comment did work. Now the post is working without any errors and i can test some drilling operations.
I am acutally using a Mori Seiki SL 200 - 2 axis machine with live tooling.
Thank you for helping me once again.
Michael
We had a similar problem with our FANUC Oi-TD and I recorded a video which hopefully might help folks in the future:
If you're interested I have more of these kind of videos on my YouTube Channel
