Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Unable to CAM a Quad Mesh
6 REPLIES 6
chrisjmulhall
489 Views, 6 Replies
Good morning,
I have a quad mesh .obj that I am trying to generate a 3axis milling toolpath from, however I am encountering various problems.
1) I cannot select the body or model as a target for the adaptive clear operation
2) Quad-Mesh to T-Spline does not solve this
I have attached the file below.
How can I generate a toolpath for this model?
Tags (3)
6 REPLIES 6
For some reason I cannot upload to the forum directly. Whenever I click "post" the file uploads, then the screen refreshes back to the same screen.
I have uploaded the file to google drive instead: https://drive.google.com/open?id=1d0HogZDvymLX87fGhm4hojjXfF7jWAAo
s.noke71
in reply to: chrisjmulhall
Hi Chris,
i think you have to insert this into a session, then you should be able to wrap some stock around it and machine it.
chrisjmulhall
in reply to: s.noke71
Have you been successful with the file I provided?
For file types blocked by the forum the easy workaround is to ZIP the file and upload. As for the quad mesh, I seem to remember the CAM only sees triangulated meshes, there is a option to triangulate the mesh on import in preferences.
Mark
Mark Hughes
Owner, Hughes Tooling
seth.madore
I would also like to point you to THIS THREAD, you may find it helpful
Seth Madore
chrisjmulhall
in reply to: seth.madore
Hi Seth,
I have managed to resolve this but ended up taking a slightly different route.
1) I saved the quad mesh as a triangulated .stl instead of a quad-mesh .obj
2) I used MeshMixer to reduce the poly count by 90% which did not affect geometry.
3) I am now able to machine the part in Fusion360 normally.
Extra steps:
I completed a simulation of the toolpath and saved the resultant shape as a new .stl. This new model is the nearly the exact mould shape I needed, which I was not able to model before. I imported the machined model back into MeshMixer to add fillets and re-ran the CAM setup.
Thank you to everyone for their suggestions.
