So I am trying to turn an arc - and the toolpaths and preview look perfect when simulating in Fusion360. When I post it - my PathPilot (LinuxCNC) controller inverts the arcs. Very weird problem I can't figure out!
The Photo on the left is the Fusion preview and toolpath which looks correct - on the right is the preview screen on my Lathe that shows the Arc bowing opposite to the toolpath in Fusion!! Argh!!
Here's the G Code that was generated with the PathPilot Post processor posted by Adam on 8/25/15.
(1)
N10 G7
N11 G18
N12 G90
N13 G20
(PROFILE3)
N14 T1010
N15 G54
N16 M08
N17 G96 D2400 S750 M03
N18 G95
N19 G90 G0 X-0.45 Z0.2125
N20 G0 Z-0.0657
N21 X-0.4092
N22 G1 X-0.2492 F0.03937
N23 X-0.2279 Z-0.0721 F0.01
N24 G18 G2 X-0.228 Z-0.135 R0.0367
N25 G3 X-0.2461 Z-0.151 R0.0186
N26 G1 X-0.4061 F0.03937
N27 G0 X-0.4092
N28 Z-0.0622
N29 G1 X-0.2492 F0.03937
N30 X-0.2248 Z-0.0695 F0.01
N31 G2 X-0.2249 Z-0.1376 R0.0397
N32 G3 X-0.2401 Z-0.151 R0.0156
N33 G1 X-0.4001 F0.03937
N34 G0 X-0.45
N35 Z0.2125
N36 M05
N37 M09
N38 M01
N39 M30
Have you read the instruction file that comes with (at least the latest version of) the post? Looks like it was updated at the end of Dec:: https://camforum.autodesk.com/index.php?topic=7481.150
I don't have this lathe (I do have a PCNC 1100 mill), but I've read a bit about the post for it. This has to do with the post being modified to handle tools on the turret, the QCTP, and gang tooling. From what I can see in the post code, if when you create the tool, you set the Turret number to something other than 0 on the "Post Processor" Tab it will be setup as toolType.XPLUS (meaning X coordinates are positive because the tool is behind the part).
this.toolType = tool.turret > 0 ? toolType.XPLUS : tool.manualToolChange ? toolType.XMINUS : toolType.GANG;
If the toolType is set to XPLUS then the G02 & G03 will be swapped:
var inverted = g_tooling.getToolInfo( getCurrentSectionId( ) ).toolType === toolType.XPLUS; var G2or3 = inverted ? clockwise ? 2 : 3 : clockwise ? 3 : 2;
Are you using the turret? Or is your tool on the front side?
Dave
Dave - thanks for the info. I had not seen that updated post.
I will try tomorrow. Hopefully that is a simple fix. I did notice it outputs I J K moves vs a Radius arc however.
-B
Yeah, some of the turning posts are setup to have a user property for useRadius that will let you select either I J K or R parameters. Looks like this one only does I J K. I would have to be modified if you want to use radius instead.
Revisions noted in the file show that as removed in this latest version: "2015-19-11 : removed 'useRadius' 'using_QCTP' properties ( deprecated )."
Maybe it also wasn't being used in the one you have so the property may be there for you to set, but have no effect.
Dave
Dave - I have seen that useRadius parameter in some posts - it seems to be cleaner - i.e. less stuff going on in the post.
I cant wait til tomorrow morning to try it out - I was pulling my hair out wondering why my lathe was doing the exact opposite of what the simulation showed.
Thanks again!
B
So just some follow up. The new post worked well. It did invert my facing op for some reason. But at least my profiling arcs were perfect - here is some 304 turned on the grizzlyG0602
