Fusion Manufacture
TRouble with adaptive facing
2 REPLIES 2
164 Views, 2 Replies
I am trying to run an op2 on a part to remove the cap left from op1. I want an adaptive facing operation so that the stock is removed from the outside to center at the entire depth of the cap.  I can not seem to come up with an operation to allow this. I tried searching forums and youtube and not came up with enough details to figure it out.  Any help is greatly appreciated.
Ed
2 REPLIES 2
Marco.Takx
Hi @Anonymous,
Can you please share your file?
Without seeing it, it is hard to help you with your problem.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
in reply to: Marco.Takx
I figured out my mistake, it was my design. I had nested several pats together and I had modeled a base to make sure everything was sitting on the same plane. Forgot to remove that base before flipping part for Op2 facing. 3d adaptive gave me the tool path I needed.
Technology Administrators
