Hi @Anonymous,
It all depends on what you are after.
Both products work perfectly for modeling and CAM
Fusion 360 has some nice functions that Inventor is missing (for example the S "Search box") but otherwise, Inventor has functionalities that are better (for example Diameter dimensions within Sketch. Within Inventor you create a center line and every dimension you make to this center line becomes automatically a diameter dimension. Within Fusion 360 you have to right-click every time to change from a normal dimension to a diameter dimension)
To choice, witch product is mostly what is the work you like to do.
When you want configuration (iLogic code configuration) then you are better of with Inventor.
For normal part modeling and CAM programming Fusion 360 is cheaper and gives you the same results as Inventor HSM.
For the learning curve, I think Fusion 360 is easier.
Inventor HSM you have to migrate Project file settings (design data and templates) every new release.
By learning Inventor -> Finding the commands can be harder. (Fusion 360 has the Search box).
But personally, I like still Inventor better.
If my post answers your question Please use
.Accept as Solution &
Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
