Toolpaths Software
Toolpaths Software
Message 1 of 8
Toolpaths Software
Hi there,
I am writing the curriculum for a new cim class for my school. We are looking at Inventor and Fusion 360 and I am looking for input on which software is better for creating a 3d model and then applying toolpaths to send it to a CNC machine. I've used Inventor and was so wondering the differences and learning curve level for Fusion 360 as well. Thank you for your help.
Sam
Replies (7)
Message 2 of 8
LibertyMachine
What grade level, what equipment (CNC) do you have, what materials are you working in?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 8
Marco.Takx
Hi @Anonymous,
It all depends on what you are after.
Both products work perfectly for modeling and CAM
Fusion 360 has some nice functions that Inventor is missing (for example the S "Search box") but otherwise, Inventor has functionalities that are better (for example Diameter dimensions within Sketch. Within Inventor you create a center line and every dimension you make to this center line becomes automatically a diameter dimension. Within Fusion 360 you have to right-click every time to change from a normal dimension to a diameter dimension)
To choice, witch product is mostly what is the work you like to do.
When you want configuration (iLogic code configuration) then you are better of with Inventor.
For normal part modeling and CAM programming Fusion 360 is cheaper and gives you the same results as Inventor HSM.
For the learning curve, I think Fusion 360 is easier.
Inventor HSM you have to migrate Project file settings (design data and templates) every new release.
By learning Inventor -> Finding the commands can be harder. (Fusion 360 has the Search box).
But personally, I like still Inventor better.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 8
Thank you for your help. I have been using Autodesk Inventor for a while and like it more. Is the HSS just an extension on Inventor?
Message 5 of 8
Marco.Takx
Hi @Anonymous,
Inventor HSM is the CAM Add-in for Inventor.
Marco Takx
Message 6 of 8
Another quick question. I've looked at my Inventor add-ins and the HMS - CAM options are not showing up. Do I have to download the extension from Autodesk for Inventor 2017, and do you know where I could find it if so?
Thank you,
Sam
Message 7 of 8
jeff.pek
What build of the add-in do you have installed? Current versions of Inventor HSM should be configured to show up and work with Inventor 2017.
Jeff
Message 8 of 8
Marco.Takx
Hi @Anonymous,
When you have a Product Design & Manufacturing Collection you can download Inventor HSM from your account.
You are talking about a Inventor 2017 release. So I don’t think you have a PD&MC so also no Inventor HSM.
There is a HSMExpress version 2,5D (free).
Or you can download a 30-days trail version of the PD&MC.
Marco Takx
