I'm getting the above warning in one of my toolpaths and I realize that it won't affect the operation but I would like to know if someone can explain what this means and what's causing it. I've attached my Fusion file for reference.
Thanks.
Solved by Steinwerks. Go to Solution.
In this case your Safe Distance is interfering with your Top Height. Set the Safe Distance to a smaller value than the top height (IE .14") and the warning goes away.
I have found this error seems to be related to Feed Height (Heights tab) being lower than the safe distance (Linking tab)
Not Top Height as stated above. @Steinwerks are you able to confirm this?
I believe the intention is to warn you when you are making a rapid feed (G0) to a distance less than your safe height.
The warning in the message log is not helpful.
This was some time ago, and yes, presumably it can interfere with any height that interferes with the feed height addition on the linking tab. I haven't looked at it specifically in a long time.
