Hi everyone,
For some reason the file I am working with is not generating a toolpath. It is a fairly simple shape and should not be causing problems. Any and all help would be appreciated.
Solved by LibertyMachine. Go to Solution.
You have chosen to use a Pocket operation, but there is no feature on the part that is actually a pocket. If you are looking to cut out the profile of the gingerbread man, you would be better off with a 2D Contour operation
