I am not able to generate a tool path after selecting edges. I imported a .svg file then inserted it into my design which I then extruded to create a body. I selected all of the edges of this body but when I generate an engraving tool path most of the edges are not being cut. I also tried a contour tool path but I get the error message "closed contour has zero area". What do I need to do to be able to generate a usable tool path? I've attached the f3d file for reference.
Solved by HughesTooling. Go to Solution.
Looks like you are not selecting the edges correctly so fusion doesn't see them a closed profiles. Screencast shows how to select closed profiles.
Mark
Mark Hughes
Owner, Hughes Tooling
