Hi, i am very new to this.
I'm stumped on a tool path i cant seem to figure out how to correct. this has been the same on all models i've created.
on a 2d adaptive clearing operation, the tool path won't run continuous pass around the full parameter of the part. it continues to cross over the piece and plunges to the other side.
I have tied adding extra stock material and didn't make a difference.
Cant seem to get past this hurdle....
Try turning on "Stock Contours". If that doesn't work, would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
when i select Stock contours it shows the tool path the same and when i go to simulate is comes up with an error about the stock material. - If i select an edge in stock contours it shows no tool path and error in simulation.
attached is the file.
thanks for your help.
If I may, are you looking for something more like the image below? If so then all I have done is turned off the Stock Contour, re-set the top/bottom and under the Linking tab set the Stay Down Level to "Most", still a little wasted movement but no more multiple plunges 🙂 Hope that gets you a little nearer 🙂
Modified file attached.
thank you, that helped!
is it common to have to add and select a bottom on the heights?
also is there a way to default "most" on the stay-down. seems like an odd tool path for default.
I do keep getting this warning on the next operations.
Its a roughing toolpath, its not expected to do a continuous toolpath around the perimeter of a part, If you want to finish it after Adaptive you should use 2D contour
All depends on what you have used to select the shape/contour, if as I did select the top edge of the shape then I had to set a bottom height because it is defaulted to the "contour selection", if I had selected the bottom shape there would have been no need to do that.
As for the default to "Least" it has to be defaulted to somewhere and most folks I think prefer to work down to a satisfactory point.
As for the continous pass @a.laasW8M6T is correct, that would be done likely with a 2D Contour
