Tool entry position option missing after latest update
sfivaz
Message 1 of 8
sfivaz
After the last update the tool entry position option at the bottom of the linking tab in the 2D chamfer function seems to have disappeared , or have I done something silly. Its still available in the 2d Contour functionInkedGUID-04AA6CB3-7071-42BD-A68C-616B3D583A15_LI.jpg
Many Thanks
Steve
Replies (7)
Message 2 of 8
jeff.pek
Hi Steve -
What is this screenshot from?
Jeff
Message 3 of 8
sfivaz
Hi Jeff,
I clicked the Info button, bottom left corner of 2D chamfer settings menu and took me here:
help.autodesk.com/view/fusion360/ENU/?guid=GUID-D1F8BDCF-9A4E-4636-AB22-B1721A3CE5FE
and scrolled down to linking tab settings.
Steve
Message 4 of 8
I am also lookting at this entry positions options that disappear from linking tab...
Message 5 of 8
jeff.pek
Hi -
Can you tell me which strategy you're using?
  Jeff
Message 6 of 8
I am doing holes in a stock.
I am willing the tool to start at the origin which bottom-left corner of the stock, but it is starting above the first hole.
Message 7 of 8
seth.madore
Circular has never had an Entry Position option. It sounds to me like your problem is not the same as what was posted by others in this thread. Can you expand on your issue any, and it might be better to start a new thread detailing what you are trying to do and what you are running into.
Seth Madore
Message 8 of 8
ok, was not thinking it was different, will do a new thread.
