Tolerance based Machining?
Hello all! I did some searching and maybe I am suing the wrong terms, but I was not able to find what I was looking for.
I would like to know if there is a way to use tolerance based machining in Fusion. My example for this would be, I color code areas with different amounts of desired stock to leave and then program against this without having to explicitly select the feature and and set the stock to leave amount.
i.e. red = leave .030, Blue = leave .020 etc.
This would be useful for me in die work while when roughing, different stock amounts are needed on different features prior to heat treat.
Thanks!
Mike
