Hi all
I have been using the attached PP lastly edited by a member here.
The original was kindly uploaded by @patrik_stellgren
For some reason I have noticed that I am unable to adjust the tool compensation length (DL) when making adjustments in the tool library on the machine. Looking over the programs that it produces it doesn't appear to output DL compensation to the program. DR, RL etc appear to being outputted.
What is needed to make this work?
Many thanks
Dan
Hi all
Many thanks
Dan
Hi Dan,
if what you are looking is simply the DL+0 on the tool call line, then this should do the trick for you.
If that's not the case, please share a code sample of what you would like to get outputted.
Hi Dan,
Hi Michael.
Thanks for your reply. I will check that out and see if works.
Many thanks
Hi Michael.
Many thanks
