I am quite new to CAM and of course, started out with a tilted 4th axis part! I have some horizontal 4th axis operations (rotary table on right side of the machine in line with X) that make nice looking tool paths that also post-process w/o issue. I am still setting up my Tormach 1100M so I don't know yet how it will run...
I have been going in circles with the tilted 4th axis. I need it tilted to get a small tool in between the teeth. I can get good looking tool paths (also look good when simulating) with the Multi-Axis Flow operation, but it won't post-process. See pictures below:
ISO View
Front View
It gives the following error when I post-process:
Information: Configuration: Tormach PathPilot
Information: Vendor: Tormach
Information: Posting intermediate data to 'C:\Temp\PostProc\1001.nc'
Information: Total number of warnings: 3
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, May 23, 2019 11:10:38 AM
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.3.0 45221
Configuration path: C:\Temp\PostProc\tormach.cps
Include paths: C:\Temp\PostProc
Configuration modification date: Monday, May 20, 2019 9:50:08 PM
Output path: C:\Temp\PostProc\1001.nc
Checksum of intermediate NC data: bb0820b50cae0715a4acda487fdc9fb6
Checksum of configuration: fb5d9ddfe1ea92e237772e2f17a41e84
Vendor url: http://www.tormach.com
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.5790
Error: Error: Direction is not supported for machine configuration.
Error at line: 1
Stack dump:
("Direction is not supported for machine configuration.")@:0
onOpen()@C:\Temp\PostProc\tormach.cps:242
Failed while processing onOpen().
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to invoke function 'onOpen'.
Error: Failed to execute configuration.
Stop time: Thursday, May 23, 2019 11:10:38 AM
Post processing failed.
I tried the 4-axis limit option through "4-axis Limit" beta mode option and it doesn't work for this one. It does work for some of my horizontal 4th axis operations.
I feel like it has something to do with the setup WCS and/or tool orientation, but I don't fully understand the implications of both of those. For the horizontal 4th axis operations that worked, I put the setup WCS in same direction as the machine's axes and put the tool orientation with the Z axis lined up with the rotary table axis.
When I do that with the tilted axis setup, the tool is at a weird angle and it doesn't post process. The tilted axis is a different cut: the horizontal axis tool path wraps around the whole part, the titled 4th axis op only does a pocket.
After writing all this up, I realized I have one good tooth space tool path. I might try post-processing that and go through the Gcode and add a repeat loop that would retract the tool, rotate the A axis and repeat the tool path. Or worst-case is I could rotate the part through Path Pilot and re-run the same program 14 times. Obviously, I would much rather fusion would take care of all this and I wouldn't have to manually code or rotate the A axis 🙂
Please explain things to me like I have no idea what I am doing since that wouldn't be too far off from reality. All help is greatly appreciated!
Cheers,
Brett
Windows 10, Suface Pro i7, 8Gb Ram
Tormach 1100M, 6" Tilting Rotary Table
