Multi-pass engraving to carve solid forms from a block of wood
Hello--
I posted this earlier to another forum, and they suggested I should be using CAM and 3D adaptive Clearing to solve my problem, and that you folks might be able to help. I'm going to settle in with the documentation right now, but in the meantime, any feedback would be appreciated. Original question:
I'm new to Slicer, but I've done enough with it to see I'll be able to do some fantastic builds using it. I believe, based on what I've seen, that it has the data to do what I want to do--I just don't know how to access it.
Instead of laying out cuts on sheets to optimize material efficiency, I want it to create a series of sheets where each level is represented faithfully in terms of objects' geometric relationships with all the other objects in that slice. I want to do that so I can send a series of full page cuts through the laser, one page after another, each one engraving in to the same thick block of wood, cutting away all the excess, layer by layer, until I'm left with a 3D wooden solid. I believe the Assembly Steps function has access to all this data--just not in a way that my laser can understand.
Does this make sense? I feel like what I'm asking for is for the app to do one fewer thing for me. I'd love to be able to convince it to try (edit: or find a more appropriate application/technique). Thanks!
