We have a thermwood 67 with the Super Control 91000, based on a 1Ghz Pentium III motherboard.
I have installed the thermwood 5 axis post processor but am having a hard time getting the gcode when I select "Got continuous C-axis" is No, as the C axis of my machine is from 0 to 360 no negative and no continuous.
Could someone please help me guide as to what else needs to change for me to get the gcode.
Attached is a sample program that I am trying to machine.
I will have a Thermwood c67 with supercontrol 91000 controller in less than 2 weeks. I am also getting the post error, I will let you know if I get it figured out. How do you like your C67?
I like it. But the operating system on my machine is very old. I hope the company updates it. Anyways did you get your machine yet and how did you make out with the post or do you have a better work-around to the problem?
I have a post working but there is a major bug I haven't had time to figure out. when I do 3+2 machining with axis 5 exactly at degrees(parallel to the table) it shift the whole coordinate system. I have used this post on a couple jobs now but its not great. Also, how do you deal with the shaky machine? Do you have a fusion post working?
What year and model of thermwood are you looking at? What are you planning to use it for. I can give you some advise. Also I may be selling my thermwood if interested.
What kind of tolerances are you expecting? Our C67 is a 2004 5' X 10' X z36" My email is matt.colvin26@gmail.com maybe we can take this conversation private since this is regards to the post processor.
I am still having issues with my "rev 2 post" machining 3+2 at 90 degrees but I haven't run the machine in 6 months so I haven't messed with it much. All my parts were complex so its not a big deal for me.
Not sure if you ever solved your problem with the orthangonal plane shift, but I had the same problem with a 5A router I built. I found changing "allowedCircularPlanes = undefined" on line 34 of the template you posted to "allowedCircularPlanes = 1; " it wil force everything to G17
I found where "undefined" = all planes, 1=G17, 2=17/18, 3=18, 4=18/19...
Hope it helps, wish I caught it earlier, the same problem haunted me for a while before I figured it out.
mhparks our issue turned out to be with Fusion360 before the post processor. Took like 6 months but on one of the updates it magically started working. I will look at your "allowedCircularPlanes" though. Thanks for the input!
