Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
The team path is not fully formed
2 REPLIES 2
Emre_Yucel
128 Views, 2 Replies
What I want is a team path with straight offsets 3 4 steps, normally when you select the contact poit option, the team should go down to the line you select, but it does not happen, can you help about this issue, which command can be done with
2 REPLIES 2
seth.madore
in reply to: Emre_Yucel
What toolpath are you using?
Can you share a sample file that shows the issue you're running into?
Seth Madore
Emre_Yucel
in reply to: seth.madore
Hello Seth,
Sure, have a nice day.
