Hi there,
Me again asking silly questions. I am going through the motions of saying goodbye to Featurecam and switching over to Fusion. Just wondering if there is a way to set machining attributes or defaults for certain cycles so I'm not having to repopulate the entire cycle page with the same data over and over again.
Is there a way to save settings on an operation in either a template or default setup page? I know from my Powermill days you would record macros as you were programming and reuse them to reprogram a similar part.
Any help would be great.
-J
Solved by DarthBane55. Go to Solution.
Solved by boopathi.sivakumar. Go to Solution.
Hi @jimmyUU9ZC
You have a option called store as a template where you can reuse the toolpath for similar model.
you can find it youtube lot of tutorials out there i will attach a couple of links here
https://www.youtube.com/watch?v=KZ7eUWPIa54
https://www.youtube.com/watch?v=feBEu41V4U0
On top of creating templates, you can set defaults as well.
I've just detailed how to do that here: https://forums.autodesk.com/t5/fusion-360-manufacture/couple-small-bugs/td-p/9533993
Just look for my post in that thread.
Awesome, I think this plus the template toolpath function should get me by for the minute. Thanks for the tip!
