T-spline model failed to convert
kunwar.khanna2021
kunwar.khanna2021
Screenshot 2021-12-24 131216.pngHi so I came across this issue saying T-spline model failed to convert. I'm not sure how do I fix this but the problem does seem to be the rims of the vehicle. It would be a great help if someone can help me fix this. I've attached the file as well 🙂
sanjana.shankar.goli
Autodesk Support
Autodesk Support
@kunwar.khanna2021
The file you shared is corrupt. I'm sharing the restored file with the rim geomtery modified. Hope it's good enough. In this design, the faces were intersecting themselves and needed to be pulled out of the intersection.
Sanjana Goli
Customer Technical Success
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
kunwar.khanna2021
Thank you so much, after I posted this question the file became corrupted. And you restored it, can't thank u enough. However a wheel is missing lol. Nevertheless, thank you for refining the overall design as well! Screenshot 2021-12-24 144319.png
