Suggestion for Milling Thread, Bore, Circular Operations: Override Cutting Feedrate with Adjusted Feedrate for Circular Interpolation
- Mute
- Permalink
- Report
I recently came across this information when I was looking up feeds and speeds for threadmilling on Harvey Tool's site. This is an issue that affects threadmilling as well as circle/bore milling, especially when milling internal hole features using tools with a diameter only a bit smaller than the diameter of a hole or the major diameter of a thread: if you just use a standard feedrate on circular features (internal & external: holes, threads, round bosses and even radii in a contour), the effective feedrate is actually different than the commanded feedrate. This can result in terrible chatter, small out-of-round holes, & possibly short lived or broken tools depending on how significant the difference is.
There is a simple formula to adjust the recommended feedrate to the adjusted circular feedrate depending on feature Ø & cutter Ø, which I use to manually enter into the cutting feedrate parameter. Then I tried creating an expression to handle this, which works rather well in the operations that require circular or cylindrical face selections like milling thread, bore, & circular, since I can use the holeTopDiameter variable along with the tool_diameter variable for any pairing of circle Ø with tool Ø.
However, I think implementing this as a feature of the operation dialogue to be able to override the tool's cutting feedrate quickly and easily would be a valuable addition to the 3 cylindrical face driven operations.
If there was also any way to implement it to work with feed optimization at radii in contouring operations and helical ramping in pocketing or adaptive strategies, I think that would also help to significantly improve the experience and the results of programming with Fusion 360.
Links to useful information on this subject:
