Somethng wrong with CAM Module! - Error: Failed to run kernel.
RepackRussian
RepackRussian
Got this error message while trying create a milling toolpath. That also happens when trying to create simple milling toolpath (circle in square).
Replies (9)
jeff.pek
RepackRussian
Hello! I run fusion 360 on windows 10!
RepackRussian
I also found difference between two different PC's
PC in my University Where i trying to use CAM Workspace
from my pc
Fusion doesn't see the cam kernel folder
jeff.pek
Hmm. Can you look in the folder %localappdata%\autodesk\webdeploy\production, and tell me what's there, and whether there are differences between the 2 PCs? In particular, look at the Application/CAM360 directory that's called out in the 2nd message.
Jeff
RepackRussian
Difference between 2 PC's is just hardware, same windows 10.
In %localappdata%\autodesk\webdeploy\production folders named like "e69ac0f55aa8512db83c718906bbdedf0daa2f89".
In C:\Users\"Username"\AppData\Local\Autodesk\webdeploy\production\a92224e805924f40fe2f5cb1ea196540cf83211e\Applications\CAM360 there are no "camkernel.exe", it was deleted somehow, only camkernel.dll.
 I think Fusion 360 need check files feature, like in Valve's Steam for games.
jeff.pek
Any given build of Fusion should have the same named folder under production in that area. If there are different ones, then they are different builds. You might have multiple of them, but if that's the case, then only one of them is likely to be populated.
For your situation, it sounds like you should uninstall/reinstall, or maybe just do an install, and it will update what you have, which should then include the camkernel.exe.
Jeff
RepackRussian
I ve done reinstaling. That doesn't work.
jeff.pek
Can you take a few screenshots of what you see in your install folder? Also, could you share your install log? It should be stored in %localappdata%\autodesk\autodesk.webdeploy.streamer.log.
  Jeff
RepackRussian
Sorry fol long time no answer. I attached log file, but i don't know where fusion 360 install folder, and what exactly you want to see?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
