I am working with an engraving that uses splines and my trace operation is machining the tangent handles of those splines. It seems obvious that the tangent handles are there only to control the splines (as per the name) and should not be selectable for machining (at least not automatically). This seems like a bug.
Repro Steps:
- Create a sketch with mirrored splines that generate tangent handles.
- Create a trace toolpath.
- Select the sketch curves using the Sketch Profiles option.
Expected Result: Only the splines are selected.
Actual Result: Splines and tangent handles are selected.
Does anyone know a workaround for this?
